REST API reference
Retrieve authentication keys associated with the admin SVM
Retrieves all authentication keys related to the admin SVM to manage or verify the associated keys effectively.
HTTP method and endpoint
GET /security/key-managers/{security_key_manager.uuid}/auth-keys
Introduced in
ONTAP 9.12
Usage notes
Retrieves a list of all authentication keys associated with the admin SVM.
  • security key-manager key query
Required properties
  • security_key_manager.uuid - UUID of the external key manager.
key_id
string
query
False
Filter by key_id
key_tag
string
query
False
Filter by key_tag
string
path
True
External key manager UUID
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[key_manager_auth_key]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "key_id": "000000000000000002000000000001003aa8ce6a4fea3e466620134bea9510a10000000000000000",
      "key_tag": "Authentication-Key-01"
Status: Default
ONTAP Error Response Codes
Error Code Description
65536074
No key servers found.
65536828
External key management is not enabled for the SVM.
65536856
65536896
External key management is not configured on the partner site.
65538800
External KMIP DKMIP keymanager not configured on administrative Vserver.
65538801
Internal error while accessing keymanager database.
65538802
The UUID provided is not associated with the administrator SVM key manager.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
_links
self_link
key_id
string
Key identifier.
key_tag
string
Optional parameter to define key-tag for the authentication key, length 0-32 characters.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
