REST API reference
Retrieve the details of a role
Accesses the details of a specific role to review its configuration and permissions within the system.
HTTP method and endpoint
GET /security/roles/{owner.uuid}/{name}
Introduced in
ONTAP 9.6
Usage notes
Retrieves the details of the specified role.
  • security login rest-role show
  • security login role show
owner.uuid
string
path
True
Role owner UUID
name
string
path
True
Role name
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
builtin
boolean
Indicates if this is a built-in (pre-defined) role which cannot be modified or deleted.
name
string
Role name
owner
owner
Owner name and UUID that uniquely identifies the role.
privileges
array[role_privilege]
The list of privileges that this role has been granted.
scope
string
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects.
      "href": "/api/resourcelink"
  "name": "admin",
  "owner": {
    "name": "svm1",
  "privileges": [
      "access": "all",
      "path": "volume move start",
      "query": "-vserver vs1|vs2|vs3 -destination-aggregate aggr1|aggr2"
  "scope": "string"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
owner
_links
_links
name
string
The name of the SVM.
uuid
string
role_privilege
A tuple containing a REST endpoint or a command/command directory path and the access level assigned to that endpoint or command/command directory. If the "path" attribute refers to a command/command directory path, the tuple could additionally contain an optional query. The REST endpoint can be a resource-qualified endpoint. At present, the only supported resource-qualified endpoints are the following
Snapshots APIs
  • /api/storage/volumes/{volume.uuid}/snapshots
File System Analytics APIs
  • /api/storage/volumes/{volume.uuid}/files
  • /api/storage/volumes/{volume.uuid}/top-metrics/clients
  • /api/storage/volumes/{volume.uuid}/top-metrics/directories
  • /api/storage/volumes/{volume.uuid}/top-metrics/files
  • /api/storage/volumes/{volume.uuid}/top-metrics/users
  • /api/svm/svms/{svm.uuid}/top-metrics/clients
  • /api/svm/svms/{svm.uuid}/top-metrics/directories
  • /api/svm/svms/{svm.uuid}/top-metrics/files
  • /api/svm/svms/{svm.uuid}/top-metrics/users
In the above APIs, wildcard character * could be used in place of {volume.uuid} or {svm.uuid} to denote all volumes or all SVMs, depending upon whether the REST endpoint references volumes or SVMs.
_links
_links
access
string
Access level for the REST endpoint or command/command directory path. If it denotes the access level for a command/command directory path, the only supported enum values are 'none','readonly' and 'all'.
path
string
Either of REST URI/endpoint OR command/command directory path.
query
string
Optional attribute that can be specified only if the "path" attribute refers to a command/command directory path. The privilege tuple implicitly defines a set of objects the role can or cannot access at the specified access level. The query further reduces this set of objects to a subset of objects that the role is allowed to access. The query attribute must be applicable to the command/command directory specified by the "path" attribute. It is defined using one or more parameters of the command/command directory path specified by the "path" attribute.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
