Retrieve the details of a role
Retrieves the details of a specified role, helping you understand the role's configuration and permissions.
HTTP method and endpoint
GET /security/roles/{owner.uuid}/{name}
Introduced in
ONTAP 9.6
Related ONTAP commands
security login rest-role show
owner.uuid |
string |
path |
True |
Role owner UUID |
name |
string |
path |
True |
Role name |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
builtin |
boolean |
Indicates if this is a built-in (pre-defined) role which cannot be modified or deleted. |
name |
string |
Role name |
owner |
Owner name and UUID that uniquely identifies the role. |
privileges |
array[role_privilege] |
The list of privileges that this role has been granted. |
scope |
string |
Scope of the entity. Set to "cluster" for cluster owned objects and to "svm" for SVM owned objects. |
"href": "/api/resourcelink"
"name": "admin",
"owner": {
"name": "svm1",
"privileges": [
"access": "readonly",
"path": "/api/storage/volumes"
"scope": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
owner
_links |
name |
string |
The name of the SVM. |
uuid |
string |
role_privilege
A tuple containing the REST endpoint and the access level assigned to that endpoint.
_links |
access |
string |
Access level for the REST endpoint. |
path |
string |
REST URI/endpoint |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
