REST API reference
Retrieve a collection of cloud stores used by an aggregate
Accesses the collection of cloud stores associated with an aggregate, which helps you manage and monitor storage resources effectively.
HTTP method and endpoint
GET /storage/aggregates/{aggregate.uuid}/cloud-stores
Introduced in
ONTAP 9.6
Usage notes
Retrieves the collection of cloud stores used by an aggregate.
  • storage aggregate object-store show
aggregate.uuid
string
path
True
Aggregate UUID
target.name
string
query
False
Filter by target.name
target.uuid
string
query
False
Filter by target.uuid
primary
boolean
query
False
Filter by primary
availability
string
query
False
Filter by availability
unreclaimed_space_threshold
integer
query
False
Filter by unreclaimed_space_threshold
aggregate.name
string
query
False
Filter by aggregate.name
  • Introduced in: 9.9
used
integer
query
False
Filter by used
mirror_degraded
boolean
query
False
Filter by mirror_degraded
unavailable_reason.message
string
query
False
Filter by unavailable_reason.message
  • Introduced in: 9.7
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[cloud_store]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "aggregate": {
        "name": "aggr1"
      "availability": "string",
      "target": {
        "name": "target1",
      "unavailable_reason": {
        "message": "string"
      "unreclaimed_space_threshold": 20,
      "used": 0
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
aggregate
Aggregate
name
string
target
Cloud target
_links
_links
name
string
uuid
string
unavailable_reason
message
string
Indicates why the object store is unavailable.
cloud_store
_links
_links
aggregate
aggregate
Aggregate
availability
string
Availability of the object store.
mirror_degraded
boolean
This field identifies if the mirror cloud store is in sync with the primary cloud store of a FabricPool.
primary
boolean
This field indicates whether the cloud store is the primary cloud store of a mirrored FabricPool.
target
target
Cloud target
unavailable_reason
unavailable_reason
integer
Usage threshold for reclaiming unused space in the cloud store. Valid values are 0 to 99. The default value depends on the provider type. This can be specified in PATCH but not POST.
used
integer
The amount of object space used. Calculated every 5 minutes and cached.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
