REST API reference
Retrieve a collection of cloud stores used by an aggregate
Retrieves a collection of cloud stores associated with an aggregate, helping you understand the cloud storage resources in use.
HTTP method and endpoint
GET /storage/aggregates/{aggregate.uuid}/cloud-stores
Introduced in
ONTAP 9.6
Usage notes
Retrieves the collection of cloud stores used by an aggregate.
  • storage aggregate object-store show
aggregate.uuid
string
path
True
Aggregate UUID
availability
string
query
False
Filter by availability
primary
boolean
query
False
Filter by primary
unavailable_reason.message
string
query
False
Filter by unavailable_reason.message
  • Introduced in: 9.7
aggregate.name
string
query
False
Filter by aggregate.name
  • Introduced in: 9.9
used
integer
query
False
Filter by used
mirror_degraded
boolean
query
False
Filter by mirror_degraded
unreclaimed_space_threshold
integer
query
False
Filter by unreclaimed_space_threshold
target.name
string
query
False
Filter by target.name
target.uuid
string
query
False
Filter by target.uuid
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[cloud_store]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "aggregate": {
        "name": "aggr1"
      "availability": "string",
      "target": {
        "name": "target1",
      "unavailable_reason": {
        "message": "string"
      "unreclaimed_space_threshold": 20,
      "used": 0
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
aggregate
Aggregate
name
string
target
Cloud target
_links
_links
name
string
uuid
string
unavailable_reason
message
string
Indicates why the object store is unavailable.
cloud_store
_links
_links
aggregate
aggregate
Aggregate
availability
string
Availability of the object store.
mirror_degraded
boolean
This field identifies if the mirror cloud store is in sync with the primary cloud store of a FabricPool.
primary
boolean
This field indicates whether the cloud store is the primary cloud store of a mirrored FabricPool.
target
target
Cloud target
unavailable_reason
unavailable_reason
integer
Usage threshold for reclaiming unused space in the cloud store. Valid values are 0 to 99. The default value depends on the provider type. This can be specified in PATCH but not POST.
used
integer
The amount of object space used. Calculated every 5 minutes and cached.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
