Retrieve a LUN attribute
Retrieves a LUN attribute to understand specific configuration details or states associated with a logical unit number (LUN).
HTTP method and endpoint
GET /storage/luns/{lun.uuid}/attributes/{name}
Introduced in
ONTAP 9.10
Learn more
lun.uuid |
string |
path |
True |
The unique identifier of the LUN. |
name |
string |
path |
True |
The name of the attribute. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
lun |
The LUN for which the attribute is set. |
name |
string |
The attribute name. Required in POST. |
value |
string |
The attribute value. Required in POST; valid in PATCH. |
"href": "/api/resourcelink"
"lun": {
"name": "name1",
"value": "value1"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5374875 |
The specified LUN was not found. |
5374931 |
The specified attribute was not found. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
lun
_links |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
