REST API reference
Retrieve a LUN attribute
Retrieves a LUN attribute to access specific information about a logical unit number in your storage environment. This can be useful for monitoring or managing your storage resources.
HTTP method and endpoint
GET /storage/luns/{lun.uuid}/attributes/{name}
Introduced in
ONTAP 9.10
lun.uuid
string
path
True
The unique identifier of the LUN.
name
string
path
True
The name of the attribute.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
lun
lun
The LUN for which the attribute is set.
name
string
The attribute name. Required in POST.
value
string
The attribute value. Required in POST; valid in PATCH.
      "href": "/api/resourcelink"
  "lun": {
  "name": "name1",
  "value": "value1"
Status: Default
ONTAP Error Response Codes
Error Code Description
5374875
The specified LUN was not found.
5374931
The specified attribute was not found.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
lun
_links
_links
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
