REST API reference
Retrieve LUN attributes
Retrieves the attributes of a LUN to understand its configuration and properties. This information helps you manage and optimize your storage resources effectively.
HTTP method and endpoint
GET /storage/luns/{lun.uuid}/attributes
Introduced in
ONTAP 9.10
Usage notes
Retrieves LUN attributes.
lun.uuid
string
path
True
The unique identifier of the LUN.
name
string
query
False
Filter by name
  • maxLength: 4091
  • minLength: 1
value
string
query
False
Filter by value
  • maxLength: 4091
  • minLength: 1
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
The number of records in the response.
records
array[lun_attribute]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "lun": {
      "name": "name1",
      "value": "value1"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
lun
The LUN for which the attribute is set.
_links
_links
uuid
string
lun_attribute
A name/value pair optionally stored with the LUN. Attributes are available to callers to persist small amounts of application-specific metadata. They are in no way interpreted by ONTAP.
Attribute names and values must be at least one byte and no more than 4091 bytes in length. The sum of the name and value lengths must be no more than 4092 bytes.
_links
_links
lun
lun
name
string
The attribute name. Required in POST.
value
string
The attribute value. Required in POST; valid in PATCH.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
