Retrieve LUN attributes
Retrieves LUN attributes to understand specific configurations and performance metrics of your logical unit numbers. This helps in monitoring and managing storage efficiency.
HTTP method and endpoint
GET /storage/luns/{lun.uuid}/attributes
Introduced in
ONTAP 9.10
Learn more
lun.uuid |
string |
path |
True |
The unique identifier of the LUN. |
name |
string |
query |
False |
Filter by name
value |
string |
query |
False |
Filter by value
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
The number of records in the response. |
records |
array[lun_attribute] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"lun": {
"name": "name1",
"value": "value1"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
lun
The LUN for which the attribute is set.
_links |
uuid |
string |
lun_attribute
A name/value pair optionally stored with the LUN. Attributes are available to callers to persist small amounts of application-specific metadata. They are in no way interpreted by ONTAP.
Attribute names and values must be at least one byte and no more than 4091 bytes in length. The sum of the name and value lengths must be no more than 4092 bytes.
_links |
lun |
The LUN for which the attribute is set. |
name |
string |
The attribute name. Required in POST. |
value |
string |
The attribute value. Required in POST; valid in PATCH. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
