Retrieve the status of legal-hold for an operation ID
Retrieves the status of legal-hold for a specific operation ID to check its current hold state. This helps you manage and review the legal-hold on your storage operations efficiently.
HTTP method and endpoint
GET /storage/snaplock/litigations/{litigation.id}/operations/{id}
Introduced in
ONTAP 9.7
Usage notes
Retrieves the status of legal-hold for the specified operation ID.
Related ONTAP commands
snaplock legal-hold show
litigation.id |
string |
path |
True |
Litigation ID |
id |
string |
path |
True |
Operation ID. |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
id |
integer |
Operation ID. |
num_files_failed |
string |
Specifies the number of files on which legal-hold operation failed. |
num_files_processed |
string |
Specifies the number of files on which legal-hold operation was successful. |
num_files_skipped |
string |
Specifies the number of files on which legal-hold begin operation was skipped. The legal-hold begin operation is skipped on a file if it is already under hold for a given litigation. |
num_inodes_ignored |
string |
Specifies the number of inodes on which the legal-hold operation was not attempted because they were not regular files. |
path |
string |
Specifies the path on which legal-hold operation is applied. |
state |
string |
Specifies the status of legal-hold operation. |
type |
string |
Specifies the type of legal-hold operation. |
"href": "/api/resourcelink"
"id": 16842759,
"num_files_failed": "0",
"num_files_processed": "30",
"num_files_skipped": "10",
"num_inodes_ignored": "10",
"path": "/dir1",
"state": "completed",
"type": "begin"
Status: Default
ONTAP Error Response codes
| Error code | Description |
14090346 |
Internal Error. Wait a few minutes, then try the command again |
14090343 |
Invalid Field |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
