REST API reference
Retrieve the status of legal-hold for an operation ID
Retrieves the status of a legal hold for a specific operation ID. This helps you monitor the current legal hold status associated with your data compliance and retention processes.
HTTP method and endpoint
GET /storage/snaplock/litigations/{litigation.id}/operations/{id}
Introduced in
ONTAP 9.7
Usage notes
Retrieves the status of legal-hold for the specified operation ID.
  • snaplock legal-hold show
litigation.id
string
path
True
Litigation ID
id
string
path
True
Operation ID.
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
id
integer
Operation ID.
num_files_failed
string
Specifies the number of files on which legal-hold operation failed.
num_files_processed
string
Specifies the number of files on which legal-hold operation was successful.
num_files_skipped
string
Specifies the number of files on which legal-hold begin operation was skipped. The legal-hold begin operation is skipped on a file if it is already under hold for a given litigation.
num_inodes_ignored
string
Specifies the number of inodes on which the legal-hold operation was not attempted because they were not regular files.
path
string
Specifies the path on which legal-hold operation is applied.
state
string
Specifies the status of legal-hold operation.
type
string
Specifies the type of legal-hold operation.
      "href": "/api/resourcelink"
  "id": 16842759,
  "num_files_failed": 0,
  "num_files_processed": 30,
  "num_files_skipped": 10,
  "num_inodes_ignored": 10,
  "path": "/dir1",
  "state": "completed",
  "type": "begin"
Status: Default
ONTAP Error Response codes
Error code Description
13763280
Only a user with security login role "vsadmin-snaplock" is allowed to perform this operation.
14090343
Invalid Field
14090346
Internal Error. Wait a few minutes, then try the command again
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
