Retrieve files and directories
Accesses files and directories within a specified directory or obtain details about a specific file or directory in a volume. This functionality is useful for managing and organizing file systems in your storage environment.
HTTP method and endpoint
GET /storage/volumes/{volume.uuid}/files/{path}
Introduced in
ONTAP 9.7
Usage notes
Retrieves a list of files and directories for a given directory or returns only the properties of a single given directory or file of a volume.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query property. See Requesting specific fields to learn more.
analytics -
qos_policy.name -
qos_policy.uuid
volume.uuid |
string |
path |
True |
Volume UUID |
path |
string |
path |
True |
Relative path of a file or directory in the volume. The path field requires using "%2E" to represent "." and "%2F" to represent "/" for the path provided. |
byte_offset |
integer |
query |
False |
The file offset to start reading from.
length |
integer |
query |
False |
Length of the range in bytes.
return_metadata |
boolean |
query |
False |
If true, the request returns metadata for the the directory or file specified in the path.
inode_number |
integer |
query |
False |
Filter by inode_number |
is_junction |
boolean |
query |
False |
Filter by is_junction |
type |
string |
query |
False |
Filter by type |
fill_enabled |
boolean |
query |
False |
Filter by fill_enabled
is_empty |
boolean |
query |
False |
Filter by is_empty |
creation_time |
string |
query |
False |
Filter by creation_time |
changed_time |
string |
query |
False |
Filter by changed_time |
constituent.name |
string |
query |
False |
Filter by constituent.name
constituent.uuid |
string |
query |
False |
Filter by constituent.uuid
qos_policy.name |
string |
query |
False |
Filter by qos_policy.name
qos_policy.uuid |
string |
query |
False |
Filter by qos_policy.uuid
analytics.file_count |
integer |
query |
False |
Filter by analytics.file_count
analytics.by_accessed_time.bytes_used.values |
integer |
query |
False |
Filter by analytics.by_accessed_time.bytes_used.values
analytics.by_accessed_time.bytes_used.labels |
string |
query |
False |
Filter by analytics.by_accessed_time.bytes_used.labels
analytics.by_accessed_time.bytes_used.newest_label |
string |
query |
False |
Filter by analytics.by_accessed_time.bytes_used.newest_label
analytics.by_accessed_time.bytes_used.percentages |
number |
query |
False |
Filter by analytics.by_accessed_time.bytes_used.percentages
analytics.by_accessed_time.bytes_used.oldest_label |
string |
query |
False |
Filter by analytics.by_accessed_time.bytes_used.oldest_label
analytics.by_modified_time.bytes_used.values |
integer |
query |
False |
Filter by analytics.by_modified_time.bytes_used.values
analytics.by_modified_time.bytes_used.labels |
string |
query |
False |
Filter by analytics.by_modified_time.bytes_used.labels
analytics.by_modified_time.bytes_used.newest_label |
string |
query |
False |
Filter by analytics.by_modified_time.bytes_used.newest_label
analytics.by_modified_time.bytes_used.percentages |
number |
query |
False |
Filter by analytics.by_modified_time.bytes_used.percentages
analytics.by_modified_time.bytes_used.oldest_label |
string |
query |
False |
Filter by analytics.by_modified_time.bytes_used.oldest_label
analytics.incomplete_data |
boolean |
query |
False |
Filter by analytics.incomplete_data
analytics.subdir_count |
integer |
query |
False |
Filter by analytics.subdir_count
analytics.bytes_used |
integer |
query |
False |
Filter by analytics.bytes_used
group_id |
integer |
query |
False |
Filter by group_id |
size |
integer |
query |
False |
Filter by size |
accessed_time |
string |
query |
False |
Filter by accessed_time |
modified_time |
string |
query |
False |
Filter by modified_time |
is_snapshot |
boolean |
query |
False |
Filter by is_snapshot
hard_links_count |
integer |
query |
False |
Filter by hard_links_count |
unix_permissions |
integer |
query |
False |
Filter by unix_permissions |
is_vm_aligned |
boolean |
query |
False |
Filter by is_vm_aligned |
unique_bytes |
integer |
query |
False |
Filter by unique_bytes
overwrite_enabled |
boolean |
query |
False |
Filter by overwrite_enabled
inode_generation |
integer |
query |
False |
Filter by inode_generation |
bytes_used |
integer |
query |
False |
Filter by bytes_used |
name |
string |
query |
False |
Filter by name |
target |
string |
query |
False |
Filter by target
owner_id |
integer |
query |
False |
Filter by owner_id |
volume.name |
string |
query |
False |
Filter by volume.name |
analytics.histogram_by_time_labels |
array[string] |
query |
False |
Request that returned analytics_histogram_by_time objects including values associated with the specified labels. As described in the object description, the labels may take the following forms:<ul> partial-date -- partial-date partial-date -- partial-date--partial-date unknown </ul>Intervals that the system would not normally return may be specified. In this case, the appropriate values and percentages summarizing all files with a time-based attribute within the indicated period of time are calculated and returned in the response. However, there are some restrictions:<ul> Any partial-date specified as the beginning or end of an interval must be tracked by the system. Valid partial-dates may be determined by making an OPTIONS request to the /storage/volumes/{volume.uuid}/files/{path} endpoint. Intervals may not mix week-based partial-dates in the form yyyy-Www with other types of partial-dates. </ul>
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
analytics |
Additional file system analytics information that is invariant amongst all elements in the collection. This property is only populated if file system analytics is enabled on the containing volume. This analytics object captures properties that are invariant amongst all elements included in the |
num_records |
integer |
Number of records. |
records |
array[file_info] |
"next": {
"href": "/api/resourcelink"
"analytics": {
"by_accessed_time": {
"bytes_used": {
"labels": [
"2019-07",
"2019-06",
"2019-05",
2019,
2018,
"--2017",
"unknown"
"by_modified_time": {
"bytes_used": {
"labels": [
"2019-07",
"2019-06",
"2019-05",
2019,
2018,
"--2017",
"unknown"
"num_records": 1,
"records": [
"metadata": {
"accessed_time": "2019-06-12T11:00:16-04:00",
"analytics": {
"bytes_used": {
"labels": [
"2019-07",
"2019-06",
"2019-05",
2019,
2018,
"--2017",
"unknown"
"newest_label": "2019-07",
"oldest_label": "2019-07",
"percentages": [
0.1,
11.24,
0.18,
15.75,
0.75,
83.5,
0
"values": [
15925248,
1735569408,
27672576,
2430595072,
116105216,
12889948160,
0
"bytes_used": {
"labels": [
"2019-07",
"2019-06",
"2019-05",
2019,
2018,
"--2017",
"unknown"
"percentages": [
0.1,
11.24,
0.18,
15.75,
0.75,
83.5,
0
"values": [
15925248,
1735569408,
27672576,
2430595072,
116105216,
12889948160,
0
"bytes_used": 15436648448,
"file_count": 21134,
"subdir_count": 35
"bytes_used": 4096,
"changed_time": "2019-06-12T11:00:16-04:00",
"constituent": {
"name": "fg__0001",
"creation_time": "2019-06-12T11:00:16-04:00",
"group_id": 30,
"hard_links_count": 1,
"inode_generation": 214753547,
"inode_number": 1695,
"is_empty": "",
"is_junction": "",
"is_snapshot": "",
"is_vm_aligned": "",
"modified_time": "2019-06-12T11:00:16-04:00",
"name": "test_file",
"owner_id": 54738,
"path": "d1/d2/d3",
"qos_policy": {
"name": "qos1",
"size": 200,
"target": "some_directory/some_other_directory/some_file",
"type": "file",
"unique_bytes": 4096,
"unix_permissions": 755,
"volume": {
"name": "volume1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
bytes_used
Number of bytes used on-disk, broken down by date of last access.
labels |
array[string] |
Labels for this histogram |
by_accessed_time
File system analytics information, broken down by date of last access.
bytes_used |
Number of bytes used on-disk, broken down by date of last access. |
bytes_used
Number of bytes used on-disk, broken down by date of last modification.
labels |
array[string] |
by_modified_time
File system analytics information, broken down by date of last modification.
bytes_used |
Number of bytes used on-disk, broken down by date of last modification. |
analytics
This analytics object captures properties that are invariant amongst all elements included in the records array. The invariant properties are included here, rather than within the information for each element, to avoid returning an excessive amount of duplicated information when the collection is large.
by_accessed_time |
File system analytics information, broken down by date of last access. |
by_modified_time |
File system analytics information, broken down by date of last modification. |
_links
metadata |
self |
bytes_used
labels |
array[string] |
newest_label |
string |
Each label indicates the period of time the corresponding data is associated with. A label can take one of the following forms:<ul> a partial date in an extended ISO8601 representation an interval between partial dates in an extended ISO8601 representation, where "--" is used to separate the beginning and end of the interval the string literal "unknown" </ul>For partial dates and partial date intervals where components of a date are unspecified, the label allows for any valid normalized values the unspecified components might take. For example, the label "2017" allows for any time within the year 2017. Essentially, this is the fully specified interval 2017-01-01T00:00:00—2017-12-31T23:59:59. Similarly, the interval "2018-05—2018-07" allows for any time within the months of May, June, and July in 2018, corresponding to the fully specified interval 2018-05-01T00:00:00—2018-07-31T23:59:59. The following extensions to ISO8601 are used:<ul> Quarters may be specified. The form yyyy-Qq is used to represent the qth quarter of the year yyyy. Q1 consists of the months January, February, and March; Q2 consists of April, May, and June; Q3 consists of July, August, and September; Q4 consists of October, November, and December. For example, the label "2019-Q2" represents the second quarter of the year 2019, which corresponds to the interval 2019-04-01T00:00:00—2019-06-30T23:59:59. Either the beginning or end of an interval may be omitted. When the beginning is omitted, the interval includes points in time arbitrarily far in the past. When the end is omitted, the interval includes points in time through the end of the current week. </ul>The "unknown" label tracks data that could not be associated with any other time period. This usually occurs when the data was at some point associated with a time in the future. |
oldest_label |
string |
percentages |
array[number] |
Percentages for this histogram |
values |
array[integer] |
Values for this histogram |
bytes_used
labels |
array[string] |
newest_label |
string |
oldest_label |
string |
percentages |
array[number] |
values |
array[integer] |
analytics
Additional file system analytics information summarizing all descendents of a directory.
In the context of the records property of a file_info_response , analytics objects will only include properties that may vary between elements within the collection. For example, the analytics objects will not contain histogram labels, since the same histogram labels are used for all elements within the collection. The invariant information is instead available via the analytics property of the file_info_response . This avoids an excessive amount of duplicated information when a GET /storage/volumes/{volume.uuid}/files/{path} call returns a large collection.
by_accessed_time |
by_modified_time |
bytes_used |
integer |
Number of bytes used on-disk |
file_count |
integer |
Number of descendants |
incomplete_data |
boolean |
Returns true if data collection is incomplete for this directory tree. |
subdir_count |
integer |
Number of sub directories |
constituent
name |
string |
FlexGroup volume constituent name. |
uuid |
string |
FlexGroup volume constituent UUID. |
_links
self |
qos_policy
The QoS policy for the file. Both traditional and adaptive QoS policies are supported. If both qos_policy.uuid and qos_policy.name properties are specified in the same request, they must refer to the same QoS policy. To remove the file from a QoS policy, set the property qos_policy.name in a PATCH request to an empty string "" or "none".
Files which are in use as a LUN cannot be assigned to a QoS policy, instead use PATCH on /storage/luns to assign a QoS policy for such files. |
Note that a QoS policy can be set on a file, or a file's volume, but not on both.
_links |
name |
string |
The name of the QoS policy. To remove the file from a QoS policy, set this property to an empty string "" or set it to "none" in a PATCH request. |
uuid |
string |
The unique identifier of the QoS policy. Valid in PATCH. |
volume
_links |
name |
string |
The name of the volume. |
uuid |
string |
file_info
Information about a single file.
| Name | Type | Description | ||
_links |
accessed_time |
string |
Last access time of the file in date-time format. |
analytics |
Additional file system analytics information summarizing all descendents of a directory. This property is only populated if file system analytics is enabled on the containing volume. In the context of the |
bytes_used |
integer |
The actual number of bytes used on disk by this file. If byte_offset and length parameters are specified, this will return the bytes used by the file within the given range. |
changed_time |
string |
Last time data or attributes changed on the file in date-time format. |
constituent |
creation_time |
string |
Creation time of the file in date-time format. |
fill_enabled |
boolean |
Returns "true" if the space reservation is enabled. The field overwrite_enabled must also be set to the same value as this field. |
group_id |
integer |
The integer ID of the group of the file owner. |
hard_links_count |
integer |
The number of hard links to the file. |
inode_generation |
integer |
Inode generation number. |
inode_number |
integer |
The file inode number. |
is_empty |
boolean |
Specifies whether or not a directory is empty. A directory is considered empty if it only contains entries for "." and "..". This element is present if the file is a directory. In some special error cases, such as when the volume goes offline or when the directory is moved while retrieving this info, this field might not get set. |
is_junction |
boolean |
Returns "true" if the directory is a junction. |
is_snapshot |
boolean |
Returns "true" if the directory is a Snapshot copy. |
is_vm_aligned |
boolean |
Returns true if the file is vm-aligned. A vm-aligned file is a file that is initially padded with zero-filled data so that its actual data starts at an offset other than zero. The amount by which the start offset is adjusted depends on the vm-align setting of the hosting volume. |
modified_time |
string |
Last data modification time of the file in date-time format. |
name |
string |
Name of the file. |
overwrite_enabled |
boolean |
Returns "true" if the space reservation for overwrites is enabled. The field fill_enabled must also be set to the same value as this field. |
owner_id |
integer |
The integer ID of the file owner. |
path |
string |
Path of the file. |
qos_policy |
Note that a QoS policy can be set on a file, or a file's volume, but not on both. |
size |
integer |
The size of the file, in bytes. |
target |
string |
The relative or absolute path contained in a symlink, in the form |
type |
string |
Type of the file. |
unique_bytes |
integer |
Number of bytes uniquely held by this file. If byte_offset and length parameters are specified, this will return bytes uniquely held by the file within the given range. |
unix_permissions |
integer |
UNIX permissions to be viewed as an octal number. It consists of 4 digits derived by adding up bits 4 (read), 2 (write), and 1 (execute). The first digit selects the set user ID(4), set group ID (2), and sticky (1) attributes. The second digit selects permissions for the owner of the file; the third selects permissions for other users in the same group; the fourth selects permissions for other users not in the group. |
volume |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
