REST API reference
Retrieve files and directories
Retrieves information about files and directories within a specified directory or obtain detailed properties for a specific directory or file in a volume. This helps you manage and organize the file system efficiently.
HTTP method and endpoint
GET /storage/volumes/{volume.uuid}/files/{path}
Introduced in
ONTAP 9.7
Usage notes
Retrieves a list of files and directories for a given directory or returns only the properties of a single given directory or file of a volume.
Expensive properties
There is an added computational cost to retrieving values for these properties. They are not included by default in GET results and must be explicitly requested using the fields query property. See Requesting specific fields to learn more.
  • analytics
  • qos_policy.name
  • qos_policy.uuid
volume.uuid
string
path
True
Volume UUID
path
string
path
True
Relative path of a file or directory in the volume. The path field requires using "%2E" to represent "." and "%2F" to represent "/" for the path provided.
byte_offset
integer
query
False
The file offset to start reading from.
  • Introduced in: 9.8
length
integer
query
False
Length of the range in bytes.
return_metadata
boolean
query
False
If true, the request returns metadata for the the directory or file specified in the path.
  • Default value:
group_id
integer
query
False
Filter by group_id
owner_id
integer
query
False
Filter by owner_id
unique_bytes
integer
query
False
Filter by unique_bytes
fill_enabled
boolean
query
False
Filter by fill_enabled
volume.name
string
query
False
Filter by volume.name
creation_time
string
query
False
Filter by creation_time
constituent.uuid
string
query
False
Filter by constituent.uuid
  • Introduced in: 9.10
constituent.name
string
query
False
Filter by constituent.name
size
integer
query
False
Filter by size
changed_time
string
query
False
Filter by changed_time
target
string
query
False
Filter by target
is_snapshot
boolean
query
False
Filter by is_snapshot
is_junction
boolean
query
False
Filter by is_junction
name
string
query
False
Filter by name
inode_generation
integer
query
False
Filter by inode_generation
qos_policy.uuid
string
query
False
Filter by qos_policy.uuid
qos_policy.name
string
query
False
Filter by qos_policy.name
modified_time
string
query
False
Filter by modified_time
is_vm_aligned
boolean
query
False
Filter by is_vm_aligned
hard_links_count
integer
query
False
Filter by hard_links_count
analytics.by_modified_time.bytes_used.newest_label
string
query
False
Filter by analytics.by_modified_time.bytes_used.newest_label
analytics.by_modified_time.bytes_used.oldest_label
string
query
False
Filter by analytics.by_modified_time.bytes_used.oldest_label
analytics.by_modified_time.bytes_used.percentages
number
query
False
Filter by analytics.by_modified_time.bytes_used.percentages
analytics.by_modified_time.bytes_used.labels
string
query
False
Filter by analytics.by_modified_time.bytes_used.labels
analytics.by_modified_time.bytes_used.values
integer
query
False
Filter by analytics.by_modified_time.bytes_used.values
analytics.bytes_used
integer
query
False
Filter by analytics.bytes_used
analytics.incomplete_data
boolean
query
False
Filter by analytics.incomplete_data
  • Introduced in: 9.12
analytics.subdir_count
integer
query
False
Filter by analytics.subdir_count
analytics.file_count
integer
query
False
Filter by analytics.file_count
analytics.by_accessed_time.bytes_used.newest_label
string
query
False
Filter by analytics.by_accessed_time.bytes_used.newest_label
analytics.by_accessed_time.bytes_used.oldest_label
string
query
False
Filter by analytics.by_accessed_time.bytes_used.oldest_label
analytics.by_accessed_time.bytes_used.percentages
number
query
False
Filter by analytics.by_accessed_time.bytes_used.percentages
analytics.by_accessed_time.bytes_used.labels
string
query
False
Filter by analytics.by_accessed_time.bytes_used.labels
analytics.by_accessed_time.bytes_used.values
integer
query
False
Filter by analytics.by_accessed_time.bytes_used.values
overwrite_enabled
boolean
query
False
Filter by overwrite_enabled
inode_number
integer
query
False
Filter by inode_number
unix_permissions
integer
query
False
Filter by unix_permissions
bytes_used
integer
query
False
Filter by bytes_used
is_empty
boolean
query
False
Filter by is_empty
type
string
query
False
Filter by type
accessed_time
string
query
False
Filter by accessed_time
analytics.histogram_by_time_labels
array[string]
query
False
Request that returned analytics_histogram_by_time objects including values associated with the specified labels.
As described in the object description, the labels may take the following forms:<ul> partial-date -- partial-date partial-date -- partial-date--partial-date unknown
</ul>Intervals that the system would not normally return may be specified. In this case, the appropriate values and percentages summarizing all files with a time-based attribute within the indicated period of time are calculated and returned in the response. However, there are some restrictions:<ul> Any partial-date specified as the beginning or end of an interval must be tracked by the system. Valid partial-dates may be determined by making an OPTIONS request to the /storage/volumes/{volume.uuid}/files/{path} endpoint. Intervals may not mix week-based partial-dates in the form yyyy-Www with other types of partial-dates.
</ul>
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
analytics
analytics
Additional file system analytics information that is invariant amongst all elements in the collection.
This property is only populated if file system analytics is enabled on the containing volume.
This analytics object captures properties that are invariant amongst all elements included in the records array. The invariant properties are included here, rather than within the information for each element, to avoid returning an excessive amount of duplicated information when the collection is large.
num_records
integer
Number of records.
records
array[file_info]
    "next": {
      "href": "/api/resourcelink"
  "analytics": {
    "by_accessed_time": {
      "bytes_used": {
        "labels": [
          "2019-07",
          "2019-06",
          "2019-05",
          "2019",
          "2018",
          "--2017",
          "unknown"
    "by_modified_time": {
      "bytes_used": {
        "labels": [
          "2019-07",
          "2019-06",
          "2019-05",
          "2019",
          "2018",
          "--2017",
          "unknown"
  "num_records": 1,
  "records": [
        "metadata": {
      "accessed_time": "2019-06-12 15:00:16 +0000",
      "analytics": {
          "bytes_used": {
            "labels": [
              "2019-07",
              "2019-06",
              "2019-05",
              "2019",
              "2018",
              "--2017",
              "unknown"
            "newest_label": "2019-07",
            "oldest_label": "2019-07",
            "percentages": [
              0.1,
              11.24,
              0.18,
              15.75,
              0.75,
              83.5,
              0
            "values": [
              15925248,
              1735569408,
              27672576,
              2430595072,
              116105216,
              12889948160,
              0
          "bytes_used": {
            "labels": [
              "2019-07",
              "2019-06",
              "2019-05",
              "2019",
              "2018",
              "--2017",
              "unknown"
            "percentages": [
              0.1,
              11.24,
              0.18,
              15.75,
              0.75,
              83.5,
              0
            "values": [
              15925248,
              1735569408,
              27672576,
              2430595072,
              116105216,
              12889948160,
              0
        "bytes_used": 15436648448,
        "file_count": 21134,
        "subdir_count": 35
      "bytes_used": 4096,
      "changed_time": "2019-06-12 15:00:16 +0000",
      "constituent": {
        "name": "fg__0001",
      "creation_time": "2019-06-12 15:00:16 +0000",
      "group_id": 30,
      "hard_links_count": 1,
      "inode_generation": 214753547,
      "inode_number": 1695,
      "is_empty": "",
      "is_junction": "",
      "is_snapshot": "",
      "is_vm_aligned": "",
      "modified_time": "2019-06-12 15:00:16 +0000",
      "name": "test_file",
      "owner_id": 54738,
      "path": "d1/d2/d3",
      "qos_policy": {
        "name": "qos1",
      "size": 200,
      "target": "some_directory/some_other_directory/some_file",
      "type": "file",
      "unique_bytes": 4096,
      "unix_permissions": 493,
      "volume": {
        "name": "volume1",
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
bytes_used
Number of bytes used on-disk, broken down by date of last access.
labels
array[string]
Labels for this histogram
by_accessed_time
File system analytics information, broken down by date of last access.
bytes_used
bytes_used
bytes_used
Number of bytes used on-disk, broken down by date of last modification.
labels
array[string]
by_modified_time
File system analytics information, broken down by date of last modification.
bytes_used
bytes_used
analytics
by_accessed_time
by_accessed_time
by_modified_time
by_modified_time
metadata
self
bytes_used
labels
array[string]
newest_label
string
Each label indicates the period of time the corresponding data is associated with. A label can take one of the following forms:<ul> a partial date in an extended ISO8601 representation an interval between partial dates in an extended ISO8601 representation, where "--" is used to separate the beginning and end of the interval the string literal "unknown"
</ul>For partial dates and partial date intervals where components of a date are unspecified, the label allows for any valid normalized values the unspecified components might take. For example, the label "2017" allows for any time within the year 2017. Essentially, this is the fully specified interval 2017-01-01T00:00:00—​2017-12-31T23:59:59. Similarly, the interval "2018-05—​2018-07" allows for any time within the months of May, June, and July in 2018, corresponding to the fully specified interval 2018-05-01T00:00:00—​2018-07-31T23:59:59.
The following extensions to ISO8601 are used:<ul> Quarters may be specified. The form yyyy-Qq is used to represent the qth quarter of the year yyyy. Q1 consists of the months January, February, and March; Q2 consists of April, May, and June; Q3 consists of July, August, and September; Q4 consists of October, November, and December. For example, the label "2019-Q2" represents the second quarter of the year 2019, which corresponds to the interval 2019-04-01T00:00:00—​2019-06-30T23:59:59. Either the beginning or end of an interval may be omitted. When the beginning is omitted, the interval includes points in time arbitrarily far in the past. When the end is omitted, the interval includes points in time through the end of the current week.
</ul>The "unknown" label tracks data that could not be associated with any other time period. This usually occurs when the data was at some point associated with a time in the future.
oldest_label
string
percentages
array[number]
Percentages for this histogram
values
array[integer]
Values for this histogram
bytes_used
labels
array[string]
newest_label
string
oldest_label
string
percentages
array[number]
values
array[integer]
analytics
Additional file system analytics information summarizing all descendents of a directory.
In the context of the records property of a file_info_response , analytics objects will only include properties that may vary between elements within the collection. For example, the analytics objects will not contain histogram labels, since the same histogram labels are used for all elements within the collection. The invariant information is instead available via the analytics property of the file_info_response . This avoids an excessive amount of duplicated information when a GET /storage/volumes/{volume.uuid}/files/{path} call returns a large collection.
by_accessed_time
by_accessed_time
by_modified_time
by_modified_time
bytes_used
integer
file_count
integer
Number of descendants
incomplete_data
boolean
Returns true if data collection is incomplete for this directory tree.
subdir_count
integer
Number of sub directories
constituent
name
string
FlexGroup volume constituent name.
uuid
string
FlexGroup volume constituent UUID.
self
qos_policy
The QoS policy for the file. Both traditional and adaptive QoS policies are supported. If both qos_policy.uuid and qos_policy.name properties are specified in the same request, they must refer to the same QoS policy. To remove the file from a QoS policy, set the property qos_policy.name in a PATCH request to an empty string "" or "none".
Note Files which are in use as a LUN cannot be assigned to a QoS policy, instead use PATCH on /storage/luns to assign a QoS policy for such files.
Note that a QoS policy can be set on a file, or a file's volume, but not on both.
_links
_links
name
string
The name of the QoS policy. To remove the file from a QoS policy, set this property to an empty string "" or set it to "none" in a PATCH request.
uuid
string
The unique identifier of the QoS policy. Valid in PATCH.
volume
_links
_links
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
file_info
Information about a single file.
_links
_links
accessed_time
string
Last access time of the file in date-time format.
analytics
analytics
bytes_used
integer
The actual number of bytes used on disk by this file. If byte_offset and length parameters are specified, this will return the bytes used by the file within the given range.
changed_time
string
Last time data or attributes changed on the file in date-time format.
constituent
constituent
creation_time
string
Creation time of the file in date-time format.
fill_enabled
boolean
Returns "true" if the space reservation is enabled. The field overwrite_enabled must also be set to the same value as this field.
group_id
integer
The integer ID of the group of the file owner.
hard_links_count
integer
The number of hard links to the file.
inode_generation
integer
Inode generation number.
inode_number
integer
The file inode number.
is_empty
boolean
Specifies whether or not a directory is empty. A directory is considered empty if it only contains entries for "." and "..". This element is present if the file is a directory. In some special error cases, such as when the volume goes offline or when the directory is moved while retrieving this info, this field might not get set.
is_junction
boolean
Returns "true" if the directory is a junction.
is_snapshot
boolean
Returns "true" if the directory is a Snapshot copy.
is_vm_aligned
boolean
Returns true if the file is vm-aligned. A vm-aligned file is a file that is initially padded with zero-filled data so that its actual data starts at an offset other than zero. The amount by which the start offset is adjusted depends on the vm-align setting of the hosting volume.
modified_time
string
Last data modification time of the file in date-time format.
name
string
Name of the file.
overwrite_enabled
boolean
Returns "true" if the space reservation for overwrites is enabled. The field fill_enabled must also be set to the same value as this field.
owner_id
integer
The integer ID of the file owner.
path
string
Path of the file.
qos_policy
qos_policy
size
integer
The size of the file, in bytes.
target
string
The relative or absolute path contained in a symlink, in the form /.
type
string
Type of the file.
unique_bytes
integer
Number of bytes uniquely held by this file. If byte_offset and length parameters are specified, this will return bytes uniquely held by the file within the given range.
unix_permissions
integer
UNIX permissions to be viewed as an octal number. It consists of 4 digits derived by adding up bits 4 (read), 2 (write), and 1 (execute). The first digit selects the set user ID(4), set group ID (2), and sticky (1) attributes. The second digit selects permissions for the owner of the file; the third selects permissions for other users in the same group; the fourth selects permissions for other users not in the group.
volume
volume
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
