Retrieve an SVM peer permission instance
GET /svm/peer-permissions/{cluster_peer.uuid}/{svm.uuid}
Introduced In: 9.6
Retrieves the SVM peer permission instance.
Related ONTAP commands
vserver peer permission show
Example
The following example shows how to retrieve the parameters for an SVM peer permission.
GET "/api/svm/peer-permissions/d3268a74-ee76-11e8-a9bb-005056ac6dc9/8f467b93-f2f1-11e8-9027-005056ac81fc"
Learn more
cluster_peer.uuid  |
string  |
path  |
True  |
Peer cluster UUID
svm.uuid  |
string  |
path  |
True  |
SVM UUID  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
return_timeout  |
integer  |
query  |
False  |
Status: 200, Ok
| Name | Type | Description |
_links  |
applications  |
array[string]  |
A list of applications for an SVM peer relation.  |
cluster_peer  |
Peer cluster details  |
svm  |
Local SVM permitted for peer relation. To create peer permissions for all SVMs, specify the SVM name as "*".  |
      "href": "/api/resourcelink"
  "applications": [
    "snapmirror",
    "flexcache"
  "cluster_peer": {
    "name": "cluster2",
    "uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
  "svm": {
    "name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error codes | Description |
26345574  |
Failed to find the SVM or volume name with UUID.  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
cluster_peer
_links  |
name  |
string  |
uuid  |
string  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
