REST API reference
Retrieve an SVM peer permission instance
GET /svm/peer-permissions/{cluster_peer.uuid}/{svm.uuid}
Introduced In: 9.6
Retrieves the SVM peer permission instance.
  • vserver peer permission show
Example
The following example shows how to retrieve the parameters for an SVM peer permission.
GET "/api/svm/peer-permissions/d3268a74-ee76-11e8-a9bb-005056ac6dc9/8f467b93-f2f1-11e8-9027-005056ac81fc"
cluster_peer.uuid
string
path
True
Peer cluster UUID
  • Introduced in: 9.7
svm.uuid
string
path
True
SVM UUID
fields
array[string]
query
False
Specify the fields to return.
return_timeout
integer
query
False
  • Default value: 1
  • Max value: 120
  • Min value: 0
Status: 200, Ok
Name Type Description
_links
_links
applications
array[string]
A list of applications for an SVM peer relationship.
cluster_peer
cluster_peer
Peer cluster details
svm
svm
Local SVM permitted for peer relationship. To create peer permissions for all SVMs, specify the SVM name as "*".
      "href": "/api/resourcelink"
  "applications": [
    "snapmirror",
    "flexcache"
  "cluster_peer": {
    "name": "cluster2",
    "uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
  "svm": {
    "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error codes Description
26345574
Failed to find the SVM or volume name with UUID.
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
cluster_peer
_links
_links
name
string
uuid
string
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
