Manage authentication keys
Create and list authentication keys associated with the admin SVM using these endpoints. Configure an external key manager on the admin SVM to associate the authentication key effectively.
Overview
Used to create and list authentication keys (NSE-AK).
Example
Creates an authentication key.
an external key manager must be configured on the admin SVM, as the authentication key will be associated with the admin SVM. The following example shows how to create an authentication key. |
# The API:
POST /api/security/key-managers/{security_key_manager.uuid}/auth-keys
# The call:
curl -X POST 'https://<mgmt-ip>/api/security/key-managers/5fb1701a-d922-11e8-bfe8-005056bb017d/auth-keys?return_timeout=15&return_records=true' -H 'accept: application/hal+json'
# The response:
"num_records": 1,
"records": [
"key_id": "00000000000000000200000000000100531d8cdc38437c2627b6b1726dd2675c0000000000000000",
"key_tag": "vsim1"
Retrieving a list of all of the authentication keys associated with the admin SVM.
The following example shows how to retrieve a list of all of the authentication keys associated with the admin SVM.
# The API:
GET /api/security/key-managers/{security_key_manager.uuid}/auth-keys
# The call:
curl -X GET 'https://<mgmt-ip>/api/security/key-managers/5fb1701a-d922-11e8-bfe8-005056bb017d/auth-keys?fields=*' -H 'accept: application/hal+json'
# The response:
"num_records": 2,
"records": [
"security_key_manager": {
"uuid": "d36a654d-14b4-11ed-b82e-005056bb8f59"
"key_id": "00000000000000000200000000000100052ab79fc51a430dbb16f1c0d2054cfe0000000000000000",
"key_tag": "vsim1"
"key_id": "000000000000000002000000000001003f32ce2dc55d2764c07da74e722c179b0000000000000000",
"key_tag": "vsim1"
Retrieving a specific authentication key associated with the admin SVM.
The following example shows how to a specific authentication key associated with the admin SVM and return the key-tag.
= The API:
GET /api/security/key-managers/{security_key_manager.uuid}/auth-keys/\{key-id}
= The call:
curl -X GET 'https://+++<mgmt-ip>+++/api/security/key-managers/5fb1701a-d922-11e8-bfe8-005056bb017d/auth-keys/0000000000000000020000000000010041a2dda969b0d179db8f1c78d629d0f10000000000000000?fields=key_tag' -H 'accept: application/hal+json'+++</mgmt-ip>+++
= The response:
"key_id": "0000000000000000020000000000010041a2dda969b0d179db8f1c78d629d0f10000000000000000",
"key_tag": "vsim1"
