REST API reference
Manage authentication keys
Create and manage authentication keys to secure interactions with the admin SVM. These endpoints require a configured external key manager, ensuring authentication keys are properly associated with the admin SVM.
Overview
Used to create and list authentication keys (NSE-AK).
Example
Creates an authentication key.
Note an external key manager must be configured on the admin SVM, as the authentication key will be associated with the admin SVM. The following example shows how to create an authentication key.
# The API:
POST /api/security/key-managers/{security_key_manager.uuid}/auth-keys
# The call:
curl -X POST 'https://<mgmt-ip>/api/security/key-managers/5fb1701a-d922-11e8-bfe8-005056bb017d/auth-keys?return_timeout=15&return_records=true' -H 'accept: application/hal+json'
# The response:
"num_records": 1,
"records": [
    "key_id": "00000000000000000200000000000100531d8cdc38437c2627b6b1726dd2675c0000000000000000",
    "key_tag": "vsim1"
Retrieving a list of all of the authentication keys associated with the admin SVM.
The following example shows how to retrieve a list of all of the authentication keys associated with the admin SVM.
# The API:
GET /api/security/key-managers/{security_key_manager.uuid}/auth-keys
# The call:
curl -X GET 'https://<mgmt-ip>/api/security/key-managers/5fb1701a-d922-11e8-bfe8-005056bb017d/auth-keys?fields=*' -H 'accept: application/hal+json'
# The response:
"num_records": 2,
"records": [
    "security_key_manager": {
      "uuid": "d36a654d-14b4-11ed-b82e-005056bb8f59"
    "key_id": "00000000000000000200000000000100052ab79fc51a430dbb16f1c0d2054cfe0000000000000000",
    "key_tag": "vsim1"
    "key_id": "000000000000000002000000000001003f32ce2dc55d2764c07da74e722c179b0000000000000000",
    "key_tag": "vsim1"
Retrieving a specific authentication key associated with the admin SVM.
The following example shows how to a specific authentication key associated with the admin SVM and return the key-tag.
= The API:
GET /api/security/key-managers/{security_key_manager.uuid}/auth-keys/\{key-id}
= The call:
curl -X GET 'https://+++<mgmt-ip>+++/api/security/key-managers/5fb1701a-d922-11e8-bfe8-005056bb017d/auth-keys/0000000000000000020000000000010041a2dda969b0d179db8f1c78d629d0f10000000000000000?fields=key_tag' -H 'accept: application/hal+json'+++</mgmt-ip>+++
= The response:
"key_id": "0000000000000000020000000000010041a2dda969b0d179db8f1c78d629d0f10000000000000000",
"key_tag": "vsim1"
