REST API reference
Manage cluster configuration backup information
Retrieve and update configuration backup settings to ensure your cluster's configuration information is securely maintained. Use these endpoints to check current backup settings or modify them as needed.
Overview
This API retrieves the current settings for the configuration and updates configuration backup settings. The GET operation retrieves the current settings for the configuration and the PATCH operation updates the configuration backup settings.
These examples show how to retrieve and update the configuration backup settings.
Retrieving the configuration backup settings
# The API:
/api/support/configuration-backup
# The call:
curl -X GET "https://<mgmt-ip>/api/support/configuration-backup" -H "accept: application/hal+json"
# The response:
  "url": "http://10.224.65.198/backups",
  "username": "me",
          "href": "/api/support/configuration-backup"
Updating the configuration backup settings
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/support/configuration-backup" -H "accept: application/hal+json"
# The body:
  "url": "https://10.224.65.198/new_backups",
  "username": "new_me",
  "password": "new_pass",
  "validate_certificate": "true"
# The response header:
HTTP/1.1 200 OK
Date: Tue, 05 Jun 2018 18:17:48 GMT
Server: libzapid-httpd
Cache-Control: no-cache,no-store,must-revalidate
Content-Length: 3
Content-Type: application/hal+json
