Manage cluster configuration backup information
Retrieve current configuration settings and update configuration backup settings using these endpoints. Access them to ensure your cluster's configuration data is consistently backed up and up-to-date.
Overview
This API retrieves the current settings for the configuration and updates configuration backup settings. The GET operation retrieves the current settings for the configuration and the PATCH operation updates the configuration backup settings.
These examples show how to retrieve and update the configuration backup settings.
Retrieving the configuration backup settings
# The API:
/api/support/configuration-backup
# The call:
curl -X GET "https://<mgmt-ip>/api/support/configuration-backup" -H "accept: application/hal+json"
# The response:
"url": "http://10.224.65.198/backups",
"username": "me",
"href": "/api/support/configuration-backup"
Updating the configuration backup settings
# The API:
# The call:
curl -X PATCH "https://<mgmt-ip>/api/support/configuration-backup" -H "accept: application/hal+json"
# The body:
"url": "https://10.224.65.198/new_backups",
"username": "new_me",
"password": "new_pass",
"validate_certificate": "true"
# The response header:
HTTP/1.1 200 OK
Date: Tue, 05 Jun 2018 18:17:48 GMT
Server: libzapid-httpd
Cache-Control: no-cache,no-store,must-revalidate
Content-Length: 3
Content-Type: application/hal+json
