REST API reference
Update the FPolicy server status
Updates the status of an FPolicy server to manage its connectivity and operational state within your environment.
HTTP method and endpoint
PATCH /protocols/fpolicy/{svm.uuid}/connections/{node.uuid}/{policy.name}/{server}
Introduced in
ONTAP 9.10
  • vserver fpolicy engine-connect
  • vserver fpolicy engine-disconnect
svm.uuid
string
path
True
node.uuid
string
path
True
Node UUID.
policy.name
string
path
True
Policy name
server
string
path
True
FPolicy Server IP address
Request Body
Name Type Description
disconnected_reason
disconnected_reason
Indicates the reason for FPolicy server disconnection.
node
node
server
string
IP address of the FPolicy server.
session_uuid
string
Unique session ID associated with each connection to the FPolicy server and it can be used to identify the established connection.
state
string
Specifies the FPolicy server connection state indicating if it is in the connected or disconnected state. The following is a list of the possible states:
  • connected - Connected
  • disconnected - Disconnected
svm
svm
type
string
FPolicy server type. The possible values are:
  • primary - Primary server
  • secondary - Secondary server
update_time
string
Specifies the time at which FPolicy server is connected or disconnected.
Example request
  "disconnected_reason": {
    "code": 9370,
    "message": "TCP Connection to FPolicy server failed."
  "node": {
    "name": "node1",
  "server": "10.132.145.20",
  "session_uuid": "5224ec64-b336-11eb-841c-0050568e14c2",
  "state": "connected",
  "svm": {
    "name": "svm1",
  "type": "primary",
  "update_time": "2019-06-12T11:00:16-04:00"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
9764954
The specified policy does not exist
9764911
Failed to connect to the FPolicy server. Reason: The specified entry does not exist
9764948
The specified policy is disabled. Using a disabled policy with this command is not supported. Use the 'fpolicy enable' command to enable the policy
9764912
Failed to disconnect the FPolicy server. Reason: The specified entry does not exist
string
disconnected_reason
code
integer
Reason ID for the FPolicy Server disconnection.
message
string
FPolicy server reason for disconnection message.
node
name
string
uuid
string
fpolicy_policy_reference
name
string
The name of the FPolicy Policy name.
svm
name
string
The name of the SVM.
uuid
string
fpolicy_connection
Displays the connection status information of the FPolicy server.
disconnected_reason
disconnected_reason
node
node
server
string
session_uuid
string
state
string
svm
svm
type
string
update_time
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
