Update the FPolicy server status
Updates the status of an FPolicy server, adjusting its connectivity state for monitoring and governing file access actions.
HTTP method and endpoint
PATCH /protocols/fpolicy/{svm.uuid}/connections/{node.uuid}/{policy.name}/{server}
Introduced in
ONTAP 9.10
Related ONTAP commands
vserver fpolicy engine-connect -
vserver fpolicy engine-disconnect
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
node.uuid |
string |
path |
True |
Node UUID. |
policy.name |
string |
path |
True |
Policy name |
server |
string |
path |
True |
FPolicy Server IP address |
Request Body
| Name | Type | Description |
disconnected_reason |
Indicates the reason for FPolicy server disconnection. |
node |
server |
string |
IP address of the FPolicy server. |
session_uuid |
string |
Unique session ID associated with each connection to the FPolicy server and it can be used to identify the established connection. |
state |
string |
Specifies the FPolicy server connection state indicating if it is in the connected or disconnected state. The following is a list of the possible states:
svm |
type |
string |
FPolicy server type. The possible values are:
update_time |
string |
Specifies the time at which FPolicy server is connected or disconnected. |
Example request
"disconnected_reason": {
"code": 9370,
"message": "TCP Connection to FPolicy server failed."
"node": {
"name": "node1",
"server": "10.132.145.20",
"session_uuid": "5224ec64-b336-11eb-841c-0050568e14c2",
"state": "connected",
"svm": {
"name": "svm1",
"type": "primary",
"update_time": "2019-06-12 15:00:16 +0000"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
9764954 |
The specified policy does not exist |
9764911 |
Failed to connect to the FPolicy server. Reason: The specified entry does not exist |
9764948 |
The specified policy is disabled. Using a disabled policy with this command is not supported. Use the 'fpolicy enable' command to enable the policy |
9764912 |
Failed to disconnect the FPolicy server. Reason: The specified entry does not exist |
href |
string |
_links
disconnected_reason
code |
integer |
Reason ID for the FPolicy Server disconnection. |
message |
string |
FPolicy server reason for disconnection message. |
node
name |
string |
uuid |
string |
self_link
fpolicy_policy_reference
name |
string |
The name of the FPolicy Policy name. |
svm
name |
string |
The name of the SVM. |
uuid |
string |
fpolicy_connection
Displays the connection status information of the FPolicy server.
node |
server |
string |
session_uuid |
string |
state |
string |
svm |
type |
string |
update_time |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
