REST API reference
Update Kerberos interface properties
Updates the properties of a Kerberos interface to configure its authentication settings or to modify existing configurations. This action is typically used when you need to adjust security settings or alter the interface's operational parameters.
HTTP method and endpoint
PATCH /protocols/nfs/kerberos/interfaces/{interface.uuid}
Introduced in
ONTAP 9.6
Optional property
  • force - Specifies whether the server should ignore any error encountered while deleting the corresponding machine account on the KDC and also disables Kerberos on the LIF. This is applicable only when disabling Kerberos.
  • vserver nfs kerberos interface modify
  • vserver nfs kerberos interface enable
  • vserver nfs kerberos interface disable
interface.uuid
string
path
True
Network interface UUID
  • Introduced in: 9.7
Request Body
Name Type Description
enabled
boolean
Specifies if Kerberos is enabled.
encryption_types
array[string]
force
boolean
interface
interface
Network interface
keytab_uri
string
Load keytab from URI
machine_account
string
Specifies the machine account to create in Active Directory.
organizational_unit
string
Organizational unit
password
string
Account creation password
spn
string
Service principal name. Valid in PATCH.
svm
svm
user
string
Account creation user name
Example request
  "encryption_types": [
    "string"
  "interface": {
    "name": "lif1",
  "keytab_uri": "string",
  "machine_account": "string",
  "organizational_unit": "string",
  "password": "string",
  "spn": "string",
  "svm": {
    "name": "svm1",
  "user": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response codes
Error codes Description
1966082
LIF could not be found in database. Contact technical support for assistance.
3276801
Failed to bind service principal name on LIF.
3276809
Failed to disable NFS Kerberos on LIF.
3276832
Failed to insert Kerberos attributes to database.
3276842
Internal error. Failed to import Kerberos keytab file into the management databases. Contact technical support for assistance.
3276861
Kerberos is already enabled/disabled on this LIF.
3276862
Kerberos service principal name is required.
3276889
Failed to enable NFS Kerberos on LIF.
3276937
Failed to lookup the Vserver for the virtual interface.
3276941
Kerberos is a required field.
3276942
Service principal name is invalid. It must of the format:"nfs/@REALM"
3276944
Internal error. Reason: Failed to initialize the Kerberos context
3276945
Internal error. Reason: Failed to parse the service principal name
3276951
Warning: Skipping unsupported encryption type for service principal name
3276952
"organizational_unit" option cannot be used for "Other" vendor.
3276965
Account sharing across Vservers is not allowed. Use a different service principal name unique within the first 15 characters.
3277019
Cannot specify -force when enabling Kerberos.
3277020
Modifying the NFS Kerberos configuration for a LIF that is not configured for NFS is not supported.
3277043
Keytab import failed due to missing keys. Keys for encryption types are required for Vserver but found no matching keys for service principal name. Generate the keytab file with all required keys and try again.
string
ip
IP information
interface
Network interface
ip
ip
IP information
name
string
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in.
uuid
string
The UUID that uniquely identifies the interface.
svm
name
string
The name of the SVM.
uuid
string
kerberos_interface
enabled
boolean
encryption_types
array[string]
force
boolean
interface
interface
Network interface
keytab_uri
string
machine_account
string
organizational_unit
string
Organizational unit
password
string
spn
string
svm
svm
user
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
