Update Kerberos interface properties
Updates the properties of a Kerberos interface to modify its configuration settings. You might use this endpoint when adjusting the interface settings for security or network requirements.
HTTP method and endpoint
PATCH /protocols/nfs/kerberos/interfaces/{interface.uuid}
Introduced in
ONTAP 9.6
Optional property
force- Specifies whether the server should ignore any error encountered while deleting the corresponding machine account on the KDC and also disables Kerberos on the LIF. This is applicable only when disabling Kerberos.
Related ONTAP commands
vserver nfs kerberos interface modify -
vserver nfs kerberos interface enable -
vserver nfs kerberos interface disable
Learn more
interface.uuid |
string |
path |
True |
Network interface UUID
Request Body
| Name | Type | Description |
enabled |
boolean |
Specifies if Kerberos is enabled. |
encryption_types |
array[string] |
force |
boolean |
Specifies whether the server should ignore any error encountered while deleting the corresponding machine account on the KDC and also disables Kerberos on the LIF. |
interface |
Network interface |
keytab_uri |
string |
Load keytab from URI |
machine_account |
string |
Specifies the machine account to create in Active Directory. |
organizational_unit |
string |
Organizational unit |
password |
string |
Account creation password |
spn |
string |
Service principal name. Valid in PATCH. |
svm |
user |
string |
Account creation user name |
Example request
"encryption_types": [
"string"
"interface": {
"name": "lif1",
"keytab_uri": "string",
"machine_account": "string",
"organizational_unit": "string",
"password": "string",
"spn": "string",
"svm": {
"name": "svm1",
"user": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response codes
| Error codes | Description |
1966082 |
LIF could not be found in database. Contact technical support for assistance. |
3276801 |
Failed to bind service principal name on LIF. |
3276809 |
Failed to disable NFS Kerberos on LIF. |
3276832 |
Failed to insert Kerberos attributes to database. |
3276842 |
Internal error. Failed to import Kerberos keytab file into the management databases. Contact technical support for assistance. |
3276861 |
Kerberos is already enabled/disabled on this LIF. |
3276862 |
Kerberos service principal name is required. |
3276889 |
Failed to enable NFS Kerberos on LIF. |
3276937 |
Failed to lookup the Vserver for the virtual interface. |
3276941 |
Kerberos is a required field. |
3276942 |
Service principal name is invalid. It must of the format:"nfs/ |
3276944 |
Internal error. Reason: Failed to initialize the Kerberos context |
3276945 |
Internal error. Reason: Failed to parse the service principal name |
3276951 |
Warning: Skipping unsupported encryption type for service principal name |
3276952 |
"organizational_unit" option cannot be used for "Other" vendor. |
3276965 |
Account sharing across Vservers is not allowed. Use a different service principal name unique within the first 15 characters. |
3277019 |
Cannot specify -force when enabling Kerberos. |
3277020 |
Modifying the NFS Kerberos configuration for a LIF that is not configured for NFS is not supported. |
3277043 |
Keytab import failed due to missing keys. Keys for encryption types are required for Vserver but found no matching keys for service principal name. Generate the keytab file with all required keys and try again. |
href |
string |
_links
ip
IP information
interface
Network interface
ip |
IP information |
name |
string |
The name of the interface. If only the name is provided, the SVM scope must be provided by the object this object is embedded in. |
uuid |
string |
The UUID that uniquely identifies the interface. |
svm
name |
string |
uuid |
string |
kerberos_interface
enabled |
boolean |
encryption_types |
array[string] |
force |
boolean |
interface |
Network interface |
keytab_uri |
string |
machine_account |
string |
string |
password |
string |
spn |
string |
svm |
user |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
