Update Kerberos interface properties
PATCH /protocols/nfs/kerberos/interfaces/{interface.uuid}
Introduced In: 9.6
Updates the properties of a Kerberos interface.
Related ONTAP commands
vserver nfs kerberos interface modify
vserver nfs kerberos interface enable
vserver nfs kerberos interface disable
Learn more
Name | Type | In | Required | Description |
interface.uuid |
string |
path |
True |
Network interface UUID
Request Body
Name | Type | Description |
enabled |
boolean |
Specifies if Kerberos is enabled. |
encryption_types |
array[string] |
interface |
Network interface |
keytab_uri |
string |
Load keytab from URI |
organizational_unit |
string |
Organizational unit |
password |
string |
Account creation password |
spn |
string |
Service principal name. Valid in PATCH. |
svm |
user |
string |
Account creation user name |
Example request
"encryption_types": [
"string"
"interface": {
"name": "lif1",
"keytab_uri": "string",
"organizational_unit": "string",
"password": "string",
"spn": "string",
"svm": {
"name": "svm1",
"user": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response codes
Error codes | Description |
1966082 |
LIF could not be found in database. Contact technical support for assistance. |
3276801 |
Failed to bind service principal name on LIF. |
3276809 |
Failed to disable NFS Kerberos on LIF. |
3276832 |
Failed to insert Kerberos attributes to database. |
3276842 |
Internal error. Failed to import Kerberos keytab file into the management databases. Contact technical support for assistance. |
3276861 |
Kerberos is already enabled/disabled on this LIF. |
3276862 |
Kerberos service principal name is required. |
3276889 |
Failed to enable NFS Kerberos on LIF. |
3276937 |
Failed to lookup the Vserver for the virtual interface. |
3276941 |
Kerberos is a required field. |
3276942 |
Service principal name is invalid. It must of the format:"nfs/ |
3276944 |
Internal error. Reason: Failed to initialize the Kerberos context |
3276945 |
Internal error. Reason: Failed to parse the service principal name |
3276951 |
Warning: Skipping unsupported encryption type for service principal name |
3276952 |
"organizational_unit" option cannot be used for "Other" vendor. |
3276965 |
Account sharing across Vservers is not allowed. Use a different service principal name unique within the first 15 characters. |
3277019 |
Cannot specify -force when enabling Kerberos. |
3277020 |
Modifying the NFS Kerberos configuration for a LIF that is not configured for NFS is not supported. |
3277043 |
Keytab import failed due to missing keys. Keys for encryption types are required for Vserver but found no matching keys for service principal name. Generate the keytab file with all required keys and try again. |
href |
string |
_links
ip
IP information
interface
Network interface
ip |
IP information |
name |
string |
The name of the interface. |
uuid |
string |
The UUID that uniquely identifies the interface. |
svm
name |
string |
The name of the SVM. |
uuid |
string |
kerberos_interface
enabled |
boolean |
encryption_types |
array[string] |
interface |
Network interface |
keytab_uri |
string |
string |
password |
string |
spn |
string |
svm |
user |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
