Update iSCSI credentials
Updates iSCSI credentials to modify authentication details for secure access to iSCSI resources. This operation is typically performed when you need to change the security settings for iSCSI connections.
HTTP method and endpoint
PATCH /protocols/san/iscsi/credentials/{svm.uuid}/{initiator}
Introduced in
ONTAP 9.6
Usage notes
Updates specified iSCSI credentials.
Related ONTAP commands
vserver iscsi security add-initiator-address-ranges -
vserver iscsi security default -
vserver iscsi security modify -
vserver iscsi security remove-initiator-address-ranges
Learn more
svm.uuid |
string |
path |
True |
The unique identifier of an SVM. |
initiator |
string |
path |
True |
The iSCSI initiator of the credentials object. |
add_initiator_addresses |
boolean |
query |
False |
If true, the initiator addresses in the body merge into the existing addresses in the iSCSI security object rather than replace the existing addresses.
remove_initiator_addresses |
boolean |
query |
False |
If true, the initiator addresses in the body are removed from the existing addresses in the iSCSI security object rather than replace the existing addresses.
Request Body
| Name | Type | Description |
authentication_type |
string |
The iSCSI authentication type. Required in POST; optional in PATCH. |
chap |
Challenge-Handshake Authentication Protocol (CHAP) credentials. |
initiator_address |
Initiator address ranges. |
svm |
Example request
"authentication_type": "string",
"chap": {
"inbound": {
"password": "string",
"user": "string"
"outbound": {
"user": "string"
"initiator_address": {
"masks": [
"address": "10.10.10.7",
"netmask": "24"
"ranges": [
"end": "10.10.10.7",
"start": "10.10.10.7"
"svm": {
"name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621462 |
An SVM with the specified UUID does not exist. |
2621706 |
Both the SVM UUID and SVM name were supplied, but they do not refer to the same SVM. |
2621707 |
No SVM was specified. Either |
5374145 |
The iSCSI security password must contain an even number of valid hex digits. |
5374147 |
The CHAP inbound and outbound passwords must be different. |
5374149 |
The inbound user and password properties are required for CHAP authentication. |
5374150 |
Outbound CHAP authentication requires an outbound password. |
5374155 |
The functionality is not supported for the default security credential. |
5374855 |
The value for property |
5374856 |
5374895 |
The iSCSI security credential does not exist on the specified SVM. |
5374900 |
Setting the CHAP authentication properties are not supported with authentication types none or deny. |
href |
string |
_links
inbound
Inbound CHAP credentials.
password |
string |
The inbound CHAP password. Write-only; optional in POST and PATCH. |
user |
string |
The inbound CHAP user name. Optional in POST and PATCH. |
outbound
Output CHAP credentials.
To clear previously set outbound CHAP credentials, set property chap.outbound.user to an empty string in PATCH.
password |
string |
The outbound CHAP password. Write-only; optional in POST and PATCH. |
user |
string |
The outbound CHAP user name. Optional in POST and PATCH. To clear previously set outbound CHAP credentials, set this property to an empty string in PATCH. |
chap
inbound |
Inbound CHAP credentials. |
outbound |
Output CHAP credentials. To clear previously set outbound CHAP credentials, set property |
ip_info
IP information
address |
string |
IPv4 or IPv6 address |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length. |
ip_address_range
IP address range
end |
string |
start |
string |
initiator_address
masks |
array[ip_info] |
ranges |
array[ip_address_range] |
svm
name |
string |
The name of the SVM. |
uuid |
string |
iscsi_credentials
string |
chap |
initiator_address |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
