REST API reference
Update iSCSI credentials
Updates iSCSI credentials to modify the security settings for your storage network. This helps ensure that your storage environment remains secure and configured correctly.
HTTP method and endpoint
PATCH /protocols/san/iscsi/credentials/{svm.uuid}/{initiator}
Introduced in
ONTAP 9.6
Usage notes
Updates specified iSCSI credentials.
  • vserver iscsi security add-initiator-address-ranges
  • vserver iscsi security default
  • vserver iscsi security modify
  • vserver iscsi security remove-initiator-address-ranges
svm.uuid
string
path
True
The unique identifier of an SVM.
initiator
string
path
True
The iSCSI initiator of the credentials object.
add_initiator_addresses
boolean
query
False
If true, the initiator addresses in the body merge into the existing addresses in the iSCSI security object rather than replace the existing addresses.
  • Default value:
remove_initiator_addresses
boolean
query
False
If true, the initiator addresses in the body are removed from the existing addresses in the iSCSI security object rather than replace the existing addresses.
  • Default value:
Request Body
Name Type Description
authentication_type
string
The iSCSI authentication type. Required in POST; optional in PATCH.
chap
chap
Challenge-Handshake Authentication Protocol (CHAP) credentials.
initiator_address
initiator_address
Initiator address ranges.
svm
svm
Example request
  "authentication_type": "string",
  "chap": {
    "inbound": {
      "password": "string",
      "user": "string"
    "outbound": {
      "user": "string"
  "initiator_address": {
    "masks": [
        "address": "10.10.10.7",
        "netmask": "24"
    "ranges": [
        "end": "10.10.10.7",
        "start": "10.10.10.7"
  "svm": {
    "name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
2621462
An SVM with the specified UUID does not exist.
2621706
Both the SVM UUID and SVM name were supplied, but they do not refer to the same SVM.
2621707
No SVM was specified. Either svm.name or svm.uuid must be supplied.
5374145
The iSCSI security password must contain an even number of valid hex digits.
5374147
The CHAP inbound and outbound passwords must be different.
5374149
The inbound user and password properties are required for CHAP authentication.
5374150
Outbound CHAP authentication requires an outbound password.
5374155
The functionality is not supported for the default security credential.
5374855
The value for property initiator_address.ranges.start is greater than the value for property initiator_address.ranges.end.
5374856
The value for property initiator_address.ranges.start does not belong to the same IP address family as the value for property initiator_address.ranges.end.
5374895
The iSCSI security credential does not exist on the specified SVM.
5374900
Setting the CHAP authentication properties are not supported with authentication types none or deny.
string
inbound
Inbound CHAP credentials.
password
string
The inbound CHAP password. Write-only; optional in POST and PATCH.
user
string
The inbound CHAP user name. Optional in POST and PATCH.
outbound
Output CHAP credentials.
To clear previously set outbound CHAP credentials, set property chap.outbound.user to an empty string in PATCH.
password
string
The outbound CHAP password. Write-only; optional in POST and PATCH.
user
string
The outbound CHAP user name. Optional in POST and PATCH.
To clear previously set outbound CHAP credentials, set this property to an empty string in PATCH.
chap
inbound
inbound
outbound
outbound
ip_info
IP information
address
string
IPv4 or IPv6 address
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length.
ip_address_range
IP address range
end
string
start
string
initiator_address
masks
array[ip_info]
ranges
array[ip_address_range]
svm
name
string
The name of the SVM.
uuid
string
iscsi_credentials
authentication_type
string
chap
chap
initiator_address
initiator_address
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
