Update an AWS KMS configuration
Updates the AWS KMS configuration to ensure the correct settings for secure key management within your ONTAP environment. This operation is typically used when adjusting security parameters or modifying access credentials for AWS KMS.
HTTP method and endpoint
PATCH /security/aws-kms/{uuid}
Introduced in
ONTAP 9.12
Optional properties
region- AWS region of the AWS KMS. -
service- AWS service type. -
default_domain- AWS KMS default domain. -
port- AWS KMS port. -
proxy_type- Type of proxy (http, https, etc.), if proxy configuration is used. -
proxy_host- Proxy hostname if proxy configuration is used. -
proxy_port- Proxy port number if proxy configuration is used. -
proxy_username- Proxy username if proxy configuration is used. -
proxy_password- Proxy password if proxy configuration is used. -
polling_period- Polling period in minutes. -
timeout- AWS Connection timeout, in seconds. -
verify- Set to true to verify the AWS KMS host. -
verify_host- Set to true to verify the AWS KMS host's hostname. -
verify_ip- Set to true to verify the AWS KMS host's IP address. -
host- AWS KMS host's hostname. -
secret_access_key- AWS secret access key for the access key ID provided. -
access-key-id- AWS access key ID of the user with the appropriate access to AWS KMS. -
skip_verify- Set to true to bypass verification of the user provided access_key_id and secret_access_key. -
encryption_context- Additional layer of authentication and logging.
Related ONTAP commands
security key-manager external aws update-config -
security key-manager external aws update-credentials
uuid |
string |
path |
True |
AWS KMS UUID |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
_links |
access_key_id |
string |
AWS Access Key ID of the user that has appropriate access to AWS KMS. |
default_domain |
string |
AWS KMS default domain. |
ekmip_reachability |
array[ekmip_reachability] |
encryption_context |
string |
Additional layer of authentication and logging. |
host |
string |
AWS KMS host's hostname. |
key_id |
string |
AWS Key ID. |
polling_period |
integer |
Polling period in minutes. |
port |
integer |
AWS KMS port. |
proxy_host |
string |
Proxy host. |
proxy_password |
string |
Proxy password. Password is not audited. |
proxy_port |
integer |
Proxy port. |
proxy_type |
string |
Proxy type. |
proxy_username |
string |
Proxy username. |
region |
string |
AWS region of the AWS KMS. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
secret_access_key |
string |
AWS Secret Access Key for the provided access key ID. |
service |
string |
AWS service type. |
skip_verify |
boolean |
Set to true to bypass verification of the user provided access_key_id and secret_access_key. An error will be returned if 'skip_verify' is provided but 'access_key_id' is not. |
svm |
timeout |
integer |
AWS Connection timeout, in seconds. |
uuid |
string |
A unique identifier for the AWS KMS. |
verify |
boolean |
Set to true to verify the AWS KMS host. |
verify_host |
boolean |
Set to true to verify the AWS KMS host's hostname. |
verify_ip |
boolean |
Set to true to verify the AWS KMS host's IP address. |
Example request
"access_key_id": "<AWS-ACCESS-KEY-ID>",
"default_domain": "domainName",
"ekmip_reachability": [
"code": "346758",
"message": "embedded KMIP server status unavailable on node.",
"node": {
"name": "node1",
"encryption_context": "aws:fsx:fs-id=fs-0785c8beceb895999",
"host": "aws-host.host.com",
"key_id": "kmip-aws",
"polling_period": 55,
"port": 443,
"proxy_host": "proxy.eng.com",
"proxy_password": "awskze-Jwjje2-WJJPer",
"proxy_port": 1234,
"proxy_type": "http",
"proxy_username": "proxyuser",
"region": "us-east-1",
"scope": "string",
"secret_access_key": "<AWS-SECRET-ACCESS-KEY>",
"service": "dynamodb.*.amazonaws.com",
"skip_verify": "",
"svm": {
"name": "svm1",
"timeout": 20,
"uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
"verify": "",
"verify_host": 1,
"verify_ip": ""
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65537541 |
No inputs provided for the REST API PATCH request. |
65537906 |
Failed to store the secret access key. |
65537920 |
Secret access key cannot be empty. |
65537921 |
Unable to connect to the Amazon Web Service Key Management Service (AWSKMS) using these credentials. |
65537924 |
Access key ID cannot be empty. |
65537926 |
Amazon Web Service Key Management Service is not configured for SVM. |
href |
string |
_links
amazon_reachability
Indicates whether or not the Amazon KMS is reachable from all nodes in the cluster.
This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code |
string |
Code corresponding to the error message. Returns a 0 if Amazon KMS is reachable from all nodes in the cluster. |
message |
string |
Error message returned when 'reachable' is false. |
reachable |
boolean |
Set to true if the Amazon KMS is reachable from all nodes of the cluster. |
node
name |
string |
uuid |
string |
ekmip_reachability
Provides the connectivity status for the given SVM on the given node to all EKMIP servers configured on all nodes of the cluster.
code |
string |
Code corresponding to the error message. Returns a 0 if a given SVM is able to communicate to the EKMIP servers of all of the nodes in the cluster. |
message |
string |
Error message set when cluster-wide EKMIP server availability from the given SVM and node is false. |
node |
reachable |
boolean |
Set to true if the given SVM on the given node is able to communicate to all EKMIP servers configured on all nodes in the cluster. |
state
Indicates whether or not the Amazon Web Services Key Management Service (AWS KMS) key protection is available cluster-wide.
cluster_state |
boolean |
Set to true when AWS KMS key protection is available on all nodes of the cluster. |
code |
string |
Code corresponding to the message. Returns a 0 if AWS KMS key protection is available on all nodes of the cluster. |
message |
string |
Error message set when cluster_state is false. |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
aws_kms
_links |
access_key_id |
string |
default_domain |
string |
string |
host |
string |
key_id |
string |
AWS Key ID. |
polling_period |
integer |
port |
integer |
AWS KMS port. |
proxy_host |
string |
Proxy host. |
proxy_password |
string |
proxy_port |
integer |
Proxy port. |
proxy_type |
string |
Proxy type. |
proxy_username |
string |
Proxy username. |
region |
string |
scope |
string |
secret_access_key |
string |
service |
string |
AWS service type. |
skip_verify |
boolean |
svm |
timeout |
integer |
uuid |
string |
verify |
boolean |
verify_host |
boolean |
verify_ip |
boolean |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
