REST API reference
Update an AWS KMS configuration
PATCH /security/aws-kms/{uuid}
Introduced In: 9.12
Updates the AWS KMS configuration.
Optional properties
  • region - AWS region of the AWS KMS.
  • service - AWS service type.
  • default_domain - AWS KMS default domain.
  • port - AWS KMS port.
  • proxy_type - Type of proxy (http, https, etc.), if proxy configuration is used.
  • proxy_host - Proxy hostname if proxy configuration is used.
  • proxy_port - Proxy port number if proxy configuration is used.
  • proxy_username - Proxy username if proxy configuration is used.
  • proxy_password - Proxy password if proxy configuration is used.
  • polling_period - Polling period in minutes.
  • timeout - AWS Connection timeout, in seconds.
  • verify - Set to true to verify the AWS KMS host.
  • verify_host - Set to true to verify the AWS KMS host's hostname.
  • verify_ip - Set to true to verify the AWS KMS host's IP address.
  • host - AWS KMS host's hostname.
  • secret_access_key - AWS secret access key for the access key ID provided.
  • access_key_id - AWS access key ID of the user with the appropriate access to AWS KMS.
  • skip_verify - Set to true to bypass verification of the user provided access_key_id and secret_access_key.
  • encryption_context - Additional layer of authentication and logging.
  • security key-manager external aws update-config
  • security key-manager external aws update-credentials
uuid
string
path
True
AWS KMS UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
_links
_links
access_key_id
string
AWS Access Key ID of the user that has appropriate access to AWS KMS.
amazon_reachability
amazon_reachability
Indicates whether or not the Amazon KMS is reachable from all nodes in the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
default_domain
string
ekmip_reachability
array[ekmip_reachability]
encryption_context
string
host
string
polling_period
integer
port
integer
AWS KMS port.
proxy_host
string
Proxy host.
proxy_password
string
Proxy password. Password is not audited.
proxy_port
integer
Proxy port.
proxy_type
string
Proxy type.
proxy_username
string
Proxy username.
region
string
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
secret_access_key
string
AWS Secret Access Key for the provided access key ID.
service
string
AWS service type.
skip_verify
boolean
Set to true to bypass verification of the user provided access_key_id and secret_access_key. An error will be returned if 'skip_verify' is provided but 'access_key_id' is not.
state
state
Indicates whether or not the Amazon Web Services Key Management Service (AWS KMS) key protection is available cluster-wide.
timeout
integer
uuid
string
A unique identifier for the AWS KMS.
verify
boolean
verify_host
boolean
verify_ip
boolean
Example request
  "access_key_id": "<AWS-ACCESS-KEY-ID>",
  "amazon_reachability": {
    "code": "346758",
    "message": "Amazon KMS is not reachable from all nodes - <reason>."
  "default_domain": "domainName",
  "ekmip_reachability": [
      "code": "346758",
      "message": "embedded KMIP server status unavailable on node.",
      "node": {
        "name": "node1",
  "encryption_context": "aws:fsx:fs-id=fs-0785c8beceb895999",
  "host": "aws-host.host.com",
  "polling_period": 55,
  "port": 443,
  "proxy_host": "proxy.eng.com",
  "proxy_password": "awskze-Jwjje2-WJJPer",
  "proxy_port": 1234,
  "proxy_type": "http",
  "proxy_username": "proxyuser",
  "region": "us-east-1",
  "scope": "string",
  "secret_access_key": "<AWS-SECRET-ACCESS-KEY>",
  "service": "dynamodb.*.amazonaws.com",
  "skip_verify": "",
  "state": {
    "code": "346758",
    "message": "AWS KMS key protection is unavailable on the following nodes: node1, node2."
  "timeout": 20,
  "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
  "verify": "",
  "verify_host": 1,
  "verify_ip": ""
Status: 200, Ok
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
65537541
No inputs provided for the REST API PATCH request.
65537906
Failed to store the secret access key.
65537920
Secret access key cannot be empty.
65537921
Unable to connect to the Amazon Web Service Key Management Service (AWSKMS) using these credentials.
65537924
Access key ID cannot be empty.
65537926
Amazon Web Service Key Management Service is not configured for SVM.
string
amazon_reachability
code
string
Code corresponding to the error message. Returns a 0 if Amazon KMS is reachable from all nodes in the cluster.
message
string
Error message returned when 'reachable' is false.
reachable
boolean
Set to true if the Amazon KMS is reachable from all nodes of the cluster.
node
name
string
uuid
string
ekmip_reachability
Provides the connectivity status for the given SVM on the given node to all EKMIP servers configured on all nodes of the cluster. This is an advanced property; there is an added computational cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
code
string
Code corresponding to the error message. Returns a 0 if a given SVM is able to communicate to the EKMIP servers of all of the nodes in the cluster.
message
string
Error message set when cluster-wide EKMIP server availability from the given SVM and node is false.
node
node
reachable
boolean
Set to true if the given SVM on the given node is able to communicate to all EKMIP servers configured on all nodes in the cluster.
state
cluster_state
boolean
Set to true when AWS KMS key protection is available on all nodes of the cluster.
code
string
Code corresponding to the message. Returns a 0 if AWS KMS key protection is available on all nodes of the cluster.
message
string
Error message set when cluster_state is false.
svm
name
string
uuid
string
aws_kms
_links
_links
access_key_id
string
amazon_reachability
amazon_reachability
default_domain
string
ekmip_reachability
encryption_context
string
host
string
polling_period
integer
port
integer
AWS KMS port.
proxy_host
string
Proxy host.
proxy_password
string
proxy_port
integer
Proxy port.
proxy_type
string
Proxy type.
proxy_username
string
Proxy username.
region
string
scope
string
secret_access_key
string
service
string
AWS service type.
skip_verify
boolean
state
state
timeout
integer
uuid
string
verify
boolean
verify_host
boolean
verify_ip
boolean
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
