Update key manager configurations
Updates key manager configurations to modify settings related to encryption management. Use this endpoint when you need to adjust key manager parameters for secure data handling.
HTTP method and endpoint
PATCH /security/key-manager-configs
Introduced in
ONTAP 9.10
Related ONTAP commands
security key-manager config modify
Request Body
| Name | Type | Description |
cc_mode_enabled |
boolean |
Indicates whether the Common Criteria Mode configuration is enabled. |
cloud_kms_retry_count |
integer |
Cloud key manager connection retry count. Supported value range of 0-10. |
health_monitor_polling_interval |
integer |
Health Monitor Polling Period, in minutes. Supported value range of 15-30 minutes. |
passphrase |
string |
Current cluster-wide passphrase. This is a required field when setting the cc_mode_enabled field value to true. This is not audited. |
Example request
"cloud_kms_retry_count": 3,
"health_monitor_polling_interval": 20,
"passphrase": "The cluster passphrase of length 64-256 ASCII characters."
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536139 |
Cluster-wide passphrase is incorrect. |
65536805 |
Common Criteria Mode requires an effective cluster version of ONTAP 9.4 or later. |
65536806 |
Passphrase length error. |
65536807 |
MetroCluster cannot be configured while in Common Criteria mode. |
65536809 |
Common Criteria mode is disabled on the cluster. Contact technical support for assistance in enabling Common Criteria mode. |
65537302 |
The passphrase field is required when changing cc_mode_enabled to true. |
65537303 |
Modifying polling period requires an effective cluster version of ONTAP 9.10 or later. |
65537304 |
Unable to modify polling period because no external key management is configured on the cluster. |
65538404 |
Modifying cloud keymanager retry count requires an effective cluster version of ONTAP 9.11 or later. |
href |
string |
self_link
key_manager_config
Manages the various key manager configuration options.
cc_mode_enabled |
boolean |
integer |
integer |
passphrase |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
