REST API reference
Update key manager configurations
Updates key manager configurations to modify the settings for managing encryption keys. Use this endpoint to adjust configurations as needed for security or operational requirements.
HTTP method and endpoint
PATCH /security/key-manager-configs
Introduced in
ONTAP 9.10
  • security key-manager config modify
Request Body
Name Type Description
cc_mode_enabled
boolean
Indicates whether the Common Criteria Mode configuration is enabled.
cloud_kms_retry_count
integer
Cloud key manager connection retry count. Supported value range of 0-10.
health_monitor_polling_interval
integer
Health Monitor Polling Period, in minutes. Supported value range of 15-30 minutes.
passphrase
string
Current cluster-wide passphrase. This is a required field when setting the cc_mode_enabled field value to true. This is not audited.
Example request
  "cloud_kms_retry_count": 3,
  "health_monitor_polling_interval": 20,
  "passphrase": "The cluster passphrase of length 64-256 ASCII characters."
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
65536139
Cluster-wide passphrase is incorrect.
65536805
Common Criteria Mode requires an effective cluster version of ONTAP 9.4 or later.
65536806
Passphrase length error.
65536807
MetroCluster cannot be configured while in Common Criteria mode.
65536809
Common Criteria mode is disabled on the cluster. Contact technical support for assistance in enabling Common Criteria mode.
65537301
The Onboard Key Manager is not enabled.
65537302
The passphrase field is required when changing cc_mode_enabled to true.
65537303
Modifying polling period requires an effective cluster version of ONTAP 9.10 or later.
65537304
Unable to modify polling period because no external key management is configured on the cluster.
65538404
Modifying cloud keymanager retry count requires an effective cluster version of ONTAP 9.11 or later.
string
key_manager_config
Manages the various key manager configuration options.
cc_mode_enabled
boolean
integer
integer
passphrase
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
