REST API reference
Update a multi-admin-verify request
Updates a multi-admin-verify request to modify its current configuration or parameters as needed for administrative verification processes.
HTTP method and endpoint
PATCH /security/multi-admin-verify/requests/{index}
Introduced in
ONTAP 9.11
index
string
path
True
Request Body
Name Type Description
approve_expiry_time
string
approve_time
string
approved_users
array[string]
The users that have approved the request.
create_time
string
execution_expiry_time
string
index
integer
Unique index that represents a request.
owner
owner
The owner of the request. This can identify the cluster or an SVM.
pending_approvers
integer
The number of approvers remaining that are required to approve.
potential_approvers
array[string]
The users that are able to approve the request.
required_approvers
integer
The number of required approvers, excluding the user that made the request.
state
string
The state of the request. PATCH supports approved and vetoed. The state only changes after setting to approved once no more approvers are required.
user_requested
string
The user that created the request. Automatically set by ONTAP.
  • readOnly: 1
  • Introduced in: 9.11
user_vetoed
string
The user that vetoed the request.
Example request
  "approve_expiry_time": "string",
  "approve_time": "string",
  "approved_users": [
    "string"
  "create_time": "string",
  "execution_expiry_time": "string",
  "index": 0,
  "owner": {
    "name": "svm1",
  "pending_approvers": 0,
  "potential_approvers": [
    "string"
  "required_approvers": 0,
  "state": "string",
  "user_requested": "string",
  "user_vetoed": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
262309
The feature must be enabled first.
262329
Invalid state for PATCH.
string
owner
name
string
The name of the SVM.
uuid
string
multi_admin_verify_request
approve_expiry_time
string
approve_time
string
approved_users
array[string]
create_time
string
string
index
integer
owner
owner
pending_approvers
integer
potential_approvers
array[string]
required_approvers
integer
state
string
user_requested
string
  • readOnly: 1
user_vetoed
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
