Update a multi-admin-verify request
Updates a multi-admin-verify request to reflect the necessary changes or corrections in the verification process.
HTTP method and endpoint
PATCH /security/multi-admin-verify/requests/{index}
Introduced in
ONTAP 9.11
index |
string |
path |
True |
Request Body
| Name | Type | Description |
approve_expiry_time |
string |
approve_time |
string |
approved_users |
array[string] |
The users that have approved the request. |
create_time |
string |
execute_on_approval |
boolean |
Specifies that the operation is executed automatically on final approval. |
execution_expiry_time |
string |
index |
integer |
Unique index that represents a request. |
owner |
The owner of the request. This can identify the cluster or an SVM. |
pending_approvers |
integer |
The number of approvers remaining that are required to approve. |
potential_approvers |
array[string] |
The users that are able to approve the request. |
required_approvers |
integer |
The number of required approvers, excluding the user that made the request. |
state |
string |
The state of the request. PATCH supports approved and vetoed. The state only changes after setting to approved once no more approvers are required. |
user_requested |
string |
The user that created the request. Automatically set by ONTAP.
user_vetoed |
string |
The user that vetoed the request. |
Example request
"approve_expiry_time": "string",
"approve_time": "string",
"approved_users": [
"string"
"create_time": "string",
"execution_expiry_time": "string",
"index": 0,
"owner": {
"name": "svm1",
"pending_approvers": 0,
"potential_approvers": [
"string"
"required_approvers": 0,
"state": "string",
"user_requested": "string",
"user_vetoed": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262309 |
The feature must be enabled first. |
262329 |
Invalid state for PATCH. |
href |
string |
_links
owner
name |
string |
The name of the SVM. |
uuid |
string |
multi_admin_verify_request
string |
approve_time |
string |
approved_users |
array[string] |
create_time |
string |
boolean |
string |
index |
integer |
owner |
pending_approvers |
integer |
array[string] |
integer |
state |
string |
user_requested |
string |
user_vetoed |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
