REST API reference
Modify multi-admin-verify configuration
Modifies the multi-admin-verify configuration to update the verification settings for administrative actions.
HTTP method and endpoint
PATCH /security/multi-admin-verify
Introduced in
ONTAP 9.11
Request Body
Name Type Description
approval_expiry
string
Default time for requests to be approved, in ISO-8601 duration format.
approval_groups
array[string]
List of approval groups that are allowed to approve requests for rules that don't have approval groups.
enabled
boolean
execution_expiry
string
Default time for requests to be executed once approved, in ISO-8601 duration format.
required_approvers
integer
The number of required approvers, excluding the user that made the request.
Example request
  "approval_expiry": "string",
  "approval_groups": [
    "string"
  "execution_expiry": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
262309
The feature must be enabled first.
262311
Value must be greater than zero.
262312
Number of required approvers must be less than the total number of unique approvers in the approval-groups.
262313
Number of unique approvers in the approval-groups must be greater than the number of required approvers.
262315
Approval-groups must be specified when enabling this feature.
262316
Value must be in the range one second to two weeks.
262318
multi-admin-verify requires an effective cluster version of ONTAP 9.11.1 or later.
multi_admin_verify_config
approval_expiry
string
approval_groups
array[string]
enabled
boolean
execution_expiry
string
required_approvers
integer
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
