Modify a multi-admin-verify configuration
Modifies the multi-admin-verify configuration to update its settings as needed for your administrative processes.
HTTP method and endpoint
PATCH /security/multi-admin-verify
Introduced in
ONTAP 9.11
Request Body
| Name | Type | Description |
approval_expiry |
string |
Default time for requests to be approved, in ISO-8601 duration format. |
approval_groups |
array[string] |
List of approval groups that are allowed to approve requests for rules that don't have approval groups. |
enabled |
boolean |
execution_expiry |
string |
Default time for requests to be executed once approved, in ISO-8601 duration format. |
required_approvers |
integer |
The number of required approvers, excluding the user that made the request. |
Example request
"approval_expiry": "string",
"approval_groups": [
"string"
"execution_expiry": "string"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262309 |
The feature must be enabled first. |
262311 |
Value must be greater than zero. |
262312 |
Number of required approvers must be less than the total number of unique approvers in the approval-groups. |
262313 |
Number of unique approvers in the approval-groups must be greater than the number of required approvers. |
262315 |
Approval-groups must be specified when enabling this feature. |
262316 |
Value must be in the range one second to two weeks. |
262318 |
multi-admin-verify requires an effective cluster version of ONTAP 9.11.1 or later. |
multi_admin_verify_config
approval_expiry |
string |
approval_groups |
array[string] |
enabled |
boolean |
execution_expiry |
string |
integer |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
