REST API reference
Update disk ownership, change authentication keys, or sanitize disks
Updates disk ownership, changes authentication keys, or sanitizes disks to manage and secure your storage environment effectively.
HTTP method and endpoint
PATCH /storage/disks
Introduced in
ONTAP 9.7
  • storage disk assign
  • storage disk removeowner
  • storage encryption disk modify -data-key-id
  • storage encryption disk sanitize
  • security key-manager key query -key-type NSE-AK
  • storage disk unfail
Learn more
name
string
query
False
Disk name
node
string
query
False
Node to assign disk
  • Introduced in: 9.8
pool
string
query
False
Pool to assign disk to
  • Introduced in: 9.11
encryption_operation
string
query
False
Name of the operation to apply to encrypting disks.
  • rekey_data_default changes the data authentication key (AK) to the drive-unique Manufacture Secure ID (MSID) value. Allows the drive to be attached to other clusters. Disables data-at-rest protection without erasing the data.
  • rekey_data_auto_id changes the data authentication key (AK) to an AK the cluster selects automatically. Enables data-at-rest protection.
  • sanitize_disk cryptographically erases all user data from a spare or broken drive by altering the data encryption key. Resets the data AK to the drive-unique MSID value and disables data-at-rest protection. Used when a drive is being repurposed or returned.
  • enum: ["rekey_data_default", "rekey_data_auto_id", "sanitize_disk"]
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
aggregates
array[aggregates]
List of aggregates sharing this disk
bay
integer
Disk shelf bay
bytes_per_sector
integer
Bytes per sector.
class
string
Disk class
compliance_standard
string
Security standard that the device is certified to.
container_type
string
Type of overlying disk container
control_standard
string
Standard that the device supports for encryption control.
drawer
drawer
effective_type
string
Effective Disk type
string
This field should only be set as a query parameter in a PATCH operation. It is input only and won't be returned by a subsequent GET.
error
array[disk_error_info]
List of disk errors information.
fips_certified
boolean
firmware_version
string
key_id
key_id
local
boolean
Indicates if a disk is locally attached versus being remotely attached. A locally attached disk resides in the same proximity as the host cluster versus been attached to the remote cluster.
model
string
name
string
Cluster-wide disk name
node
node
outage
outage
Indicates if a disk has an entry in the failed disk registry, along with the reason for the failure.
overall_security
string
Overall Security rating, for FIPS-certified devices.
paths
array[disk_path_info]
List of paths to a disk
physical_size
integer
Physical size, in units of bytes
pool
string
Pool to which disk is assigned
protection_mode
string
Mode of drive data protection and FIPS compliance. Possible values are:
  • open - Data is unprotected
  • data - Data protection only, without FIPS compliance
  • part - Data is unprotected; other FIPS compliance settings present
  • full - Full data and FIPS compliance protection
  • miss - Protection mode information is not available
rated_life_used_percent
integer
Percentage of rated life used
right_size_sector_count
integer
Number of usable disk sectors that remain after subtracting the right-size adjustment for this disk.
rpm
integer
Revolutions per minute
sector_count
integer
Number of sectors on the disk.
self_encrypting
boolean
serial_number
string
state
string
State
stats
stats
type
string
Disk interface type
uid
string
The unique identifier for a disk
usable_size
integer
vendor
string
virtual
virtual
Information about backing storage for disks on cloud platforms.
Example request
  "aggregates": [
      "name": "aggr1",
  "bay": 1,
  "bytes_per_sector": 520,
  "class": "solid_state",
  "compliance_standard": "FIPS 140-2",
  "container_type": "spare",
  "control_standard": "TCG Enterprise",
  "effective_type": "vmdisk",
  "encryption_operation": "string",
  "error": [
      "type": "notallflashdisk"
  "firmware_version": "NA51",
  "key_id": {
    "data": "string",
    "fips": "string"
  "model": "X421_HCOBE450A10",
  "name": "1.0.1",
  "node": {
    "name": "node1",
  "overall_security": "Level 2",
  "paths": [
      "initiator": "3a",
      "node.name": "vsim4",
      "node.uuid": "cf7fe057-526d-11ec-af4e-0050568e9df0",
      "port_name": "A",
      "port_type": "sas",
      "vmdisk_hypervisor_file_name": "xvds vol0a0567ae156ca59f6",
      "wwnn": "5000c2971c1b2b8c",
      "wwpn": "5000c2971c1b2b8d"
  "physical_size": 228930,
  "pool": "pool0",
  "protection_mode": "data",
  "rated_life_used_percent": 10,
  "right_size_sector_count": 1172123568,
  "rpm": 15000,
  "sector_count": 1172123568,
  "serial_number": "KHG2VX8R",
  "state": "present",
  "stats": {
    "average_latency": 3,
    "iops_total": 12854,
    "path_error_count": 0,
    "power_on_hours": 21016,
    "throughput": 1957888
  "type": "ssd",
  "uid": "002538E5:71B00B2F:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000",
  "usable_size": 959934889984,
  "vendor": "NETAPP",
  "virtual": {
    "container": "nviet12122018113936-rg",
    "object": "f1fu63se",
    "storage_account": "nviet12122018113936ps"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
720951
Unable to unfail the disk.
721066
Node is outside the list of controllers for disk.
1441795
Setting the data key ID to the manufacture secure ID is not allowed when in FIPS-compliance mode.
1441825
The system does not support maintenance of the controls of encrypting disks.
14155777
The operation failed on one or more disks.
14155778
No self-encrypting disks were specified.
14155779
Status from a node shows that a conflicting operation has occurred. Some disk controls might have changed.
14155780
Could not retrieve the required key ID from the key manager.
string
aggregates
_links
_links
name
string
uuid
string
dr_node
name
string
uuid
string
drawer
id
integer
slot
integer
code
string
Argument code
message
string
Message argument
error
The message and code detailing the error state of this disk.
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
disk_error_info
type
string
Disk error type.
home_node
_links
_links
name
string
uuid
string
key_id
data
string
Key ID of the data authentication key
fips
string
Key ID of the FIPS authentication key
node
_links
_links
name
string
uuid
string
error
This error message and code explaining the disk failure.
arguments
Message arguments
code
string
Error code
message
string
Error message
target
string
outage
persistently_failed
boolean
Indicates whether RAID maintains the state of this disk as failed accross reboots.
disk_path_info
initiator
string
Initiator port.
node.name
string
Controller with the initiator port for this path.
node.uuid
string
Controller UUID, to identify node for this path.
port_name
string
Name of the disk port.
port_type
string
Disk port type.
string
Virtual disk hypervisor file name.
wwnn
string
Target device's World Wide Node Name.
wwpn
string
Target device's World Wide Port Name.
shelf
Shelf
_links
_links
uid
string
stats
average_latency
integer
Average I/O latency across all active paths, in milliseconds.
iops_total
integer
Total I/O operations per second read and written to this disk across all active paths.
path_error_count
integer
Disk path error count; failed I/O operations.
power_on_hours
integer
Hours powered on.
throughput
integer
Total disk throughput per second across all active paths, in bytes.
storage_pool
Shared Storage Pool
_links
_links
name
string
uuid
string
virtual
container
string
Container name of the virtual disk.
object
string
Object name of the virtual disk.
storage_account
string
Storage account name of the virtual disk.
disk
aggregates
array[aggregates]
bay
integer
Disk shelf bay
bytes_per_sector
integer
Bytes per sector.
class
string
Disk class
compliance_standard
string
container_type
string
control_standard
string
drawer
drawer
effective_type
string
Effective Disk type
string
error
fips_certified
boolean
firmware_version
string
key_id
key_id
local
boolean
model
string
name
string
node
node
outage
outage
overall_security
string
paths
physical_size
integer
pool
string
protection_mode
string
integer
integer
rpm
integer
sector_count
integer
self_encrypting
boolean
serial_number
string
state
string
State
stats
stats
type
string
Disk interface type
uid
string
usable_size
integer
vendor
string
virtual
virtual
