Update disk ownership, change authentication keys, or sanitize disks
Updates disk ownership, change authentication keys, or sanitize disks as needed to manage your storage environment effectively.
HTTP method and endpoint
PATCH /storage/disks
Introduced in
ONTAP 9.7
Usage notes
Updates disk ownership, changes authentication keys, or sanitizes disks.
Related ONTAP commands
storage disk assign -
storage encryption disk modify -data-key-id -
storage encryption disk sanitize -
security key-manager key query -key-type NSE-AK
Learn more
name |
string |
query |
False |
Disk name |
node |
string |
query |
False |
Node to assign disk
encryption_operation |
string |
query |
False |
Name of the operation to apply to encrypting disks.
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
aggregates |
array[aggregates] |
List of aggregates sharing this disk |
bay |
integer |
Disk shelf bay |
bytes_per_sector |
integer |
Bytes per sector. |
class |
string |
Disk class |
container_type |
string |
Type of overlying disk container |
drawer |
effective_type |
string |
Effective Disk type |
string |
This field should only be set as a query parameter in a PATCH operation. It is input only and won't be returned by a subsequent GET. |
error |
array[disk_error_info] |
List of disk errors information. |
fips_certified |
boolean |
firmware_version |
string |
key_id |
local |
boolean |
Indicates if a disk is locally attached versus being remotely attached. A locally attached disk resides in the same proximity as the host cluster versus been attached to the remote cluster. |
model |
string |
name |
string |
Cluster-wide disk name |
node |
outage |
Indicates if a disk has an entry in the failed disk registry, along with the reason for the failure. |
paths |
array[disk_path_info] |
List of paths to a disk |
pool |
string |
Pool to which disk is assigned |
protection_mode |
string |
Mode of drive data protection and FIPS compliance. Possible values are:
rated_life_used_percent |
integer |
Percentage of rated life used |
rpm |
integer |
Revolutions per minute |
sector_count |
integer |
Number of sectors on the disk. |
self_encrypting |
boolean |
serial_number |
string |
state |
string |
State |
stats |
type |
string |
Disk interface type |
uid |
string |
The unique identifier for a disk |
usable_size |
integer |
vendor |
string |
Example request
"aggregates": [
"name": "aggr1",
"bay": "1",
"bytes_per_sector": "520",
"class": "solid_state",
"container_type": "spare",
"effective_type": "vmdisk",
"encryption_operation": "string",
"error": [
"reason": {
"code": "string",
"message": "not responding"
"type": "notallflashdisk"
"firmware_version": "NA51",
"key_id": {
"data": "string",
"fips": "string"
"model": "X421_HCOBE450A10",
"name": "1.0.1",
"node": {
"name": "node1",
"outage": {
"reason": {
"code": "721081",
"paths": [
"initiator": "3a",
"port_name": "A",
"port_type": "sas",
"wwnn": "5000c2971c1b2b8c",
"wwpn": "5000c2971c1b2b8d"
"pool": "pool0",
"protection_mode": "string",
"rated_life_used_percent": "10",
"rpm": "15000",
"sector_count": "1172123568",
"serial_number": "KHG2VX8R",
"state": "present",
"stats": {
"average_latency": "3",
"iops_total": "12854",
"path_error_count": "0",
"power_on_hours": "21016",
"throughput": "1957888"
"type": "ssd",
"uid": "002538E5:71B00B2F:00000000:00000000:00000000:00000000:00000000:00000000:00000000:00000000",
"usable_size": "959934889984",
"vendor": "NETAPP"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
721066 |
Node is outside the list of controllers for disk. |
1441795 |
Setting the data key ID to the manufacture secure ID is not allowed when in FIPS-compliance mode. |
14155777 |
The operation failed on one or more disks. |
14155778 |
No self-encrypting disks were specified. |
14155779 |
Status from a node shows that a conflicting operation has occurred. Some disk controls might have changed. |
14155780 |
Could not retrieve the required key ID from the key manager. |
14155786 |
Changes to encryption controls are not allowed with drive assignment. |
href |
string |
_links
aggregates
Aggregate
name |
string |
uuid |
string |
dr_node
name |
string |
uuid |
string |
drawer
id |
integer |
slot |
integer |
reason
code |
string |
Provides an error code. |
message |
string |
Provides an error message detailing the error state of this disk. |
disk_error_info
reason |
type |
string |
Disk error type. |
home_node
name |
string |
uuid |
string |
key_id
data |
string |
Key ID of the data authentication key |
fips |
string |
Key ID of the FIPS authentication key |
node
name |
string |
uuid |
string |
reason
code |
string |
This field provides the error code explaining why a disk failed. |
message |
string |
This field provides the error message explaining why a disk failed. |
outage
persistently_failed |
boolean |
Indicates whether RAID maintains the state of this disk as failed accross reboots. |
reason |
disk_path_info
initiator |
string |
Initiator port. |
port_name |
string |
Name of the disk port. |
port_type |
string |
Disk port type. |
wwnn |
string |
Target device's World Wide Node Name. |
wwpn |
string |
Target device's World Wide Port Name. |
shelf
uid |
string |
stats
average_latency |
integer |
Average I/O latency across all active paths, in milliseconds. |
iops_total |
integer |
Total I/O operations per second read and written to this disk across all active paths. |
path_error_count |
integer |
Disk path error count; failed I/O operations. |
power_on_hours |
integer |
Hours powered on. |
throughput |
integer |
Total disk throughput per second across all active paths, in bytes. |
disk
aggregates |
array[aggregates] |
bay |
integer |
Disk shelf bay |
bytes_per_sector |
integer |
Bytes per sector. |
class |
string |
Disk class |
container_type |
string |
drawer |
effective_type |
string |
string |
error |
fips_certified |
boolean |
firmware_version |
string |
key_id |
local |
boolean |
model |
string |
name |
string |
node |
outage |
paths |
pool |
string |
protection_mode |
string |
integer |
rpm |
integer |
sector_count |
integer |
self_encrypting |
boolean |
serial_number |
string |
state |
string |
State |
stats |
type |
string |
uid |
string |
usable_size |
integer |
vendor |
string |
