REST API reference
Update the AutoSupport configuration for an entire cluster
Updates the AutoSupport configuration for the entire cluster, ensuring the settings align with your operational requirements. Use this endpoint to modify AutoSupport to fit your support and monitoring needs.
HTTP method and endpoint
PATCH /support/autosupport
Introduced in
ONTAP 9.6
  • system node autosupport modify
Request Body
Name Type Description
contact_support
boolean
Specifies whether to send the AutoSupport messages to vendor support.
enabled
boolean
Specifies whether the AutoSupport daemon is enabled. When this setting is disabled, delivery of all AutoSupport messages is turned off.
from
string
The e-mail address from which the AutoSupport messages are sent. To generate node-specific 'from' addresses, enable '-node-specific-from' parameter via ONTAP CLI.
is_minimal
boolean
Specifies whether the system information is collected in compliant form, to remove private data or in complete form, to enhance diagnostics.
issues
array[autosupport_issues]
A list of nodes in the cluster with connectivity issues to HTTP/SMTP/AOD AutoSupport destinations along with the corresponding error descriptions and corrective actions.
mail_hosts
array[string]
The names of the mail servers used to deliver AutoSupport messages via SMTP.
partner_addresses
array[string]
The list of partner addresses.
proxy_url
string
Proxy server for AutoSupport message delivery via HTTP/S. Optionally specify a username/password for authentication with the proxy server.
to
array[string]
The e-mail addresses to which the AutoSupport messages are sent.
transport
string
The name of the transport protocol used to deliver AutoSupport messages.
Note Support for 'http' transport has been deprecated and might be removed in a future version of ONTAP.
  • Default value: 1
  • enum: ["smtp", "http", "https"]
  • example: smtp
  • Introduced in: 9.6
Example request
  "contact_support": 1,
  "enabled": 1,
  "from": "postmaster@example.com",
  "is_minimal": 1,
  "issues": [
      "corrective_action": {
        "code": "53149746",
        "message": "Check the hostname of the SMTP server"
      "issue": {
        "code": "53149746",
        "message": "SMTP connectivity check failed for destination: mailhost. Error: Could not resolve host - 'mailhost'"
      "node": {
        "name": "node1",
  "mail_hosts": [
    "mailhost1.example.com",
    "mailhost2.example.com"
  "partner_addresses": [
    "user1@partner.com",
    "user2@partner.com"
  "proxy_url": "https://proxy.company.com",
  "to": [
    "user1@example.com",
    "user2@example.com"
  "transport": "smtp"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
8650862
The SMTP mail host provided cannot be empty
8650863
A maximum of 5 SMTP mail hosts can be provided
8650864
A maximum of 5 email addresses can be provided
8650865
A maximum of 5 partner email addresses can be provided
8650880
Automatic update requires AutoSupport to be enabled.
8650881
Automatic update requires AutoSupport to use the HTTPS transport.
8650882
Automatic update requires AutoSupport OnDemand to be enabled.
53149727
The proxy URI provided is invalid
53149728
The mailhost URI provided is invalid
autosupport_connectivity_corrective_action
code
string
Corrective action code
message
string
Corrective action message. The corrective action might contain commands which needs to be executed on the ONTAP CLI.
  • example: Check the hostname of the SMTP server
  • readOnly: 1
autosupport_connectivity_issue
code
string
Error code
message
string
Error message
string
node
_links
_links
name
string
uuid
string
autosupport_issues
corrective_action
issue
node
node
autosupport
contact_support
boolean
enabled
boolean
from
string
is_minimal
boolean
issues
mail_hosts
array[string]
partner_addresses
array[string]
proxy_url
string
to
array[string]
transport
string
  • Default value: 1
  • example: smtp
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
