REST API reference
Update the AutoSupport configuration for an entire cluster
Updates the AutoSupport configuration for the entire cluster to ensure that system diagnostics and alerts are managed according to your preferences.
HTTP method and endpoint
PATCH /support/autosupport
Introduced in
ONTAP 9.6
  • system node autosupport modify
Request Body
Name Type Description
contact_support
boolean
Specifies whether to send the AutoSupport messages to vendor support.
enabled
boolean
Specifies whether the AutoSupport daemon is enabled. When this setting is disabled, delivery of all AutoSupport messages is turned off.
from
string
The e-mail address from which the AutoSupport messages are sent. To generate node-specific 'from' addresses, enable '-node-specific-from' parameter via ONTAP CLI.
is_minimal
boolean
Specifies whether the system information is collected in compliant form, to remove private data or in complete form, to enhance diagnostics.
issues
array[autosupport_issues]
A list of connectivity issues to the HTTPS/SMTP/AOD AutoSupport destinations on the nodes in the cluster along with the corrective actions.
mail_hosts
array[string]
The names of the mail servers used to deliver AutoSupport messages via SMTP.
partner_addresses
array[string]
The list of partner addresses.
proxy_url
string
Proxy server for AutoSupport message delivery via HTTPS. Optionally specify a username/password for authentication with the proxy server.
smtp_encryption
string
The encryption protocol used to deliver AutoSupport messages via SMTP to the configured mail_hosts.
to
array[string]
The e-mail addresses to which the AutoSupport messages are sent.
transport
string
The name of the transport protocol used to deliver AutoSupport messages.
Note 'http' transport is no longer supported by AutoSupport servers.
Example request
  "contact_support": 1,
  "enabled": 1,
  "from": "postmaster@example.com",
  "is_minimal": 1,
  "issues": [
      "component": "mail_server",
      "corrective_action": {
        "code": "53149746",
        "message": "Check the hostname of the SMTP server"
      "destination": "mailhost1.example.com",
      "issue": {
        "code": "53149746",
        "message": "SMTP connectivity check failed for destination: mailhost. Error: Could not resolve host - 'mailhost'"
      "node": {
        "name": "node1",
  "mail_hosts": [
    "mailhost2.example.com"
  "partner_addresses": [
    "user1@partner.com",
    "user2@partner.com"
  "proxy_url": "proxy.company.com",
  "smtp_encryption": "none",
  "to": [
    "user1@example.com",
    "user2@example.com"
  "transport": "smtp"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
8650862
The SMTP mail host provided cannot be empty
8650863
A maximum of 5 SMTP mail hosts can be provided
8650864
A maximum of 5 email addresses can be provided
8650865
A maximum of 5 partner email addresses can be provided
8650880
Automatic update requires AutoSupport to be enabled
8650881
Automatic update requires AutoSupport to use the HTTPS transport
8650882
Automatic update requires AutoSupport OnDemand to be enabled
8650886
The provided parameter requires an effective cluster version of ONTAP 9.15.1 or later
8650887
Username or password is not allowed in the AutoSupport url and put-url fields
53149727
The proxy URI provided is invalid
53149728
The SMTP mail host URI provided is invalid
53149732
The proxy URI provided is invalid. IPv6 addresses must be enclosed within square brackets
53149737
The proxy URI provided specifies an unsupported scheme
autosupport_connectivity_corrective_action
code
string
Corrective action code
message
string
Corrective action message. The corrective action might contain commands which needs to be executed on the ONTAP CLI.
  • example: Check the hostname of the SMTP server
  • readOnly: 1
  • Introduced in: 9.6
  • x-nullable: true
autosupport_connectivity_issue
code
string
Error code
message
string
Error message
string
node
name
string
uuid
string
autosupport_issues
component
string
The name of the component where the issue occurred.
corrective_action
destination
string
The HTTPS/SMTP/AOD AutoSupport Destination.
issue
node
node
autosupport
contact_support
boolean
enabled
boolean
from
string
is_minimal
boolean
issues
mail_hosts
array[string]
partner_addresses
array[string]
proxy_url
string
smtp_encryption
string
to
array[string]
transport
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
