REST API reference
Restore an application Snapshot copy
Restores an application Snapshot copy to revert storage elements to their state at the time the Snapshot was taken. This is useful for recovering data to a known point without affecting access settings that may have changed since the Snapshot creation.
HTTP method and endpoint
POST /application/applications/{application.uuid}/snapshots/{uuid}/restore
Introduced in
ONTAP 9.6
Usage notes
Restore an application snapshot
Restoring an application Snapshot copy reverts all storage elements in the Snapshot copy to the state in which the Snapshot copy was in when the Snapshot copy was taken. This restoration does not apply to access settings that might have changed since the Snapshot copy was created.
application.uuid
string
path
True
Application UUID
uuid
string
path
True
Snapshot copy UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Status: 202, Accepted
Name Type Description
job
job_link
  "job": {
    "uuid": "string"
Status: Default, Error
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
