REST API reference
Restore an application snapshot
Restores an application snapshot, reverting all storage elements to their previous state at the time the snapshot was taken. Use this to recover an application to a known good state without affecting access settings that have changed since the snapshot.
HTTP method and endpoint
POST /application/applications/{application.uuid}/snapshots/{uuid}/restore
Introduced in
ONTAP 9.6
Usage notes
Restoring an application snapshot reverts all storage elements in the snapshot to the state in which the snapshot was in when the snapshot was taken. This restoration does not apply to access settings that might have changed since the snapshot was created.
application.uuid
string
path
True
Application UUID
uuid
string
path
True
Snapshot UUID
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Status: 202, Accepted
Name Type Description
job
job_link
  "job": {
    "uuid": "string"
Status: 201, Created
Status: Default, Error
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
