Validate an external NTP time server
Validates an external NTP time server to ensure it is suitable for synchronization and configure the cluster to use it across all nodes.
HTTP method and endpoint
POST /cluster/ntp/servers
Introduced in
ONTAP 9.7
Usage notes
Validates the provided external NTP time server for usage and configures ONTAP so that all nodes in the cluster use it. The required fields are:
server
Default property values
If not specified in POST, the following default property values are assigned:
version- auto -
key- not set
If the key is provided in POST, authentication_enabled is set to true by default.
Related ONTAP commands
cluster time-service ntp server create
Learn more
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
key |
server |
string |
NTP server host name, IPv4, or IPv6 address. |
version |
string |
NTP protocol version for server. Valid versions are 3, 4, or auto. |
Example request
"authentication_enabled": 1,
"key": {
"id": 10
"server": "time.nist.gov",
"version": "auto"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2097163 |
NTP server IPv4 address was invalid. |
2097164 |
NTP server IPv6 address was invalid. |
2097165 |
Cannot resolve NTP server name. |
2097166 |
NTP server address query returned no valid IP addresses. |
2097167 |
Failed to connect to NTP server. |
2097169 |
NTP server provided was not synchronized with a clock or another NTP server. |
2097174 |
NTP server provided had too high of root distance. |
2097177 |
NTP server provided an invalid stratum. |
2097179 |
Too many NTP servers have been configured. |
2097181 |
NTP server address was invalid. It is a special purpose address such as loopback, multicast, or broadcast address. |
2097182 |
NTP server address was invalid. The address is neither an IPv4 or IPv6. |
2097183 |
NTP symmetric key authentication cannot be used for a node not in a cluster. |
2097185 |
NTP key authentication failed for the provided key. |
2097193 |
An unknown NTP key was provided. |
href |
string |
_links
ntp_key_reference
id |
integer |
NTP symmetric authentication key identifier or index number (ID). This ID, the type of cryptographic hash, and the cryptographic hash value are all provided by the remote NTP server. |
ntp_server
key |
server |
string |
version |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
