REST API reference
Validate an external NTP time server
Validates an external NTP time server to ensure accurate time synchronization across all nodes in the cluster.
HTTP method and endpoint
POST /cluster/ntp/servers
Introduced in
ONTAP 9.7
Usage notes
Validates the provided external NTP time server for usage and configures ONTAP so that all nodes in the cluster use it. The required fields are:
  • server
Default property values
If not specified in POST, the following default property values are assigned:
  • version - auto
  • key - not set
If the key is provided in POST, authentication_enabled is set to true by default.
  • cluster time-service ntp server create
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
key
ntp_key_reference
server
string
NTP server host name, IPv4, or IPv6 address.
version
string
NTP protocol version for server. Valid versions are 3, 4, or auto.
Example request
  "authentication_enabled": 1,
  "key": {
    "id": 10
  "server": "time.nist.gov",
  "version": "auto"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
2097163
NTP server IPv4 address was invalid.
2097164
NTP server IPv6 address was invalid.
2097165
Cannot resolve NTP server name.
2097166
NTP server address query returned no valid IP addresses.
2097167
Failed to connect to NTP server.
2097168
Unable to query NTP server.
2097169
NTP server provided was not synchronized with a clock or another NTP server.
2097174
NTP server provided had too high of root distance.
2097177
NTP server provided an invalid stratum.
2097179
Too many NTP servers have been configured.
2097181
NTP server address was invalid. It is a special purpose address such as loopback, multicast, or broadcast address.
2097182
NTP server address was invalid. The address is neither an IPv4 or IPv6.
2097183
NTP symmetric key authentication cannot be used for a node not in a cluster.
2097185
NTP key authentication failed for the provided key.
2097193
An unknown NTP key was provided.
string
ntp_key_reference
id
integer
NTP symmetric authentication key identifier or index number (ID). This ID, the type of cryptographic hash, and the cryptographic hash value are all provided by the remote NTP server.
ntp_server
key
ntp_key_reference
server
string
version
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
