Validate an external NTP time server
POST /cluster/ntp/servers
Introduced In: 9.7
Validates the provided external NTP time server for usage and configures ONTAP so that all nodes in the cluster use it. The required fields are:
server
Default property values
If not specified in POST, the following default property values are assigned:
version- auto -
key- not set
If the key is provided in POST, authentication_enabled is set to true by default.
Related ONTAP commands
cluster time-service ntp server create
Learn more
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
key |
server |
string |
NTP server host name, IPv4, or IPv6 address. |
version |
string |
NTP protocol version for server. Valid versions are 3, 4, or auto. |
Example request
"authentication_enabled": 1,
"key": {
"id": "10"
"server": "time.nist.gov",
"version": "auto"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2097163 |
NTP server IPv4 address was invalid. |
2097164 |
NTP server IPv6 address was invalid. |
2097165 |
Cannot resolve NTP server name. |
2097166 |
NTP server address query returned no valid IP addresses. |
2097167 |
Failed to connect to NTP server. |
2097169 |
NTP server provided was not synchronized with a clock or another NTP server. |
2097174 |
NTP server provided had too high of root distance. |
2097177 |
NTP server provided an invalid stratum. |
2097179 |
Too many NTP servers have been configured. |
2097181 |
NTP server address was invalid. It is a special purpose address such as loopback, multicast, or broadcast address. |
2097182 |
NTP server address was invalid. The address is neither an IPv4 or IPv6. |
2097183 |
NTP symmetric key authentication cannot be used for a node not in a cluster. |
2097185 |
NTP key authentication failed for the provided key. |
2097193 |
An unknown NTP key was provided. |
href |
string |
_links
ntp_key_reference
id |
integer |
NTP symmetric authentication key identifier or index number (ID). This ID, the type of cryptographic hash, and the cryptographic hash value are all provided by the remote NTP server. |
ntp_server
key |
server |
string |
version |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
