Create a schedule
Creates a schedule to automate tasks based on specified timing criteria, such as cron or interval settings. Use this endpoint to manage routine operations efficiently by defining when they should occur.
HTTP method and endpoint
POST /cluster/schedules
Introduced in
ONTAP 9.6
Required Fields
name - Name of the job schedule. You must provide a minutes field for a cron schedule and an interval field for an interval schedule. Do not provide both a cron field and an interval field.
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
cluster |
The cluster that owns the schedule. Defaults to the local cluster. |
cron |
Details for schedules of type cron. |
interval |
string |
An ISO-8601 duration formatted string. |
name |
string |
Schedule name. Required in the URL or POST body. |
scope |
string |
If the schedule is owned by a data SVM, then the scope is set to svm. Otherwise it will be set to cluster. |
svm |
type |
string |
Schedule type |
uuid |
string |
Job schedule UUID |
Example request
"cluster": {
"name": "cluster1",
"cron": {
"days": [
"integer"
"hours": [
"integer"
"minutes": [
"integer"
"months": [
"integer"
"weekdays": [
"integer"
"interval": "P1DT2H3M4S",
"name": "string",
"scope": "string",
"svm": {
"name": "svm1",
"type": "string",
Status: 201, Created
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
458788 |
The schedule specified is not a valid schedule. |
459760 |
459763 |
Schedule cannot be created locally using the remote cluster name as the owner. |
459764 |
Cannot create a schedule with the same name as an existing schedule from the MetroCluster partner cluster but of a different schedule type. |
460783 |
As this is a MetroCluster configuration and the local cluster is waiting for switchback, changes to non-system schedules are not allowed. |
460784 |
An error occurred creating the remote cluster version of this schedule. |
href |
string |
_links
cluster
name |
string |
Cluster name |
uuid |
string |
Cluster UUID |
cron
days |
array[integer] |
The days of the month the schedule runs. Leave empty for all. |
hours |
array[integer] |
The hours of the day the schedule runs. Leave empty for all. |
minutes |
array[integer] |
The minutes the schedule runs. Required on POST for a cron schedule. |
months |
array[integer] |
The months of the year the schedule runs. Leave empty for all. |
weekdays |
array[integer] |
The weekdays the schedule runs. Leave empty for all. |
svm
name |
string |
The name of the SVM. |
uuid |
string |
schedule
Complete schedule information
cluster |
cron |
interval |
string |
name |
string |
scope |
string |
svm |
type |
string |
Schedule type |
uuid |
string |
Job schedule UUID |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
