REST API reference
Creates a schedule
you must provide a minutes field for a cron schedule and an interval field for an interval schedule do not provide both a cron field and an interval field
POST /cluster/schedules
Introduced In: 9.6
Creates a schedule.
Required Fields
  • name - Name of the job schedule. You must provide a minutes field for a cron schedule and an interval field for an interval schedule. Do not provide both a cron field and an interval field.
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
cluster
cluster
The cluster that owns the schedule. Defaults to the local cluster.
cron
cron
Details for schedules of type cron.
interval
string
An ISO-8601 duration formatted string.
name
string
Schedule name. Required in the URL or POST body.
scope
string
If the schedule is owned by a data SVM, then the scope is set to svm. Otherwise it will be set to cluster.
svm
svm
type
string
Schedule type
uuid
string
Job schedule UUID
Example request
  "cluster": {
    "name": "cluster1",
  "cron": {
    "days": [
      "integer"
    "hours": [
      "integer"
    "minutes": [
      "integer"
    "months": [
      "integer"
    "weekdays": [
      "integer"
  "interval": "P1DT2H3M4S",
  "name": "string",
  "scope": "string",
  "svm": {
    "name": "svm1",
  "type": "string",
Status: 201, Created
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
458788
The schedule specified is not a valid schedule.
459760
459763
Schedule cannot be created locally using the remote cluster name as the owner.
459764
Cannot create a schedule with the same name as an existing schedule from the MetroCluster partner cluster but of a different schedule type.
460783
As this is a MetroCluster configuration and the local cluster is waiting for switchback, changes to non-system schedules are not allowed.
460784
An error occurred creating the remote cluster version of this schedule.
string
cluster
name
string
Cluster name
uuid
string
Cluster UUID
cron
days
array[integer]
The days of the month the schedule runs. Leave empty for all.
hours
array[integer]
The hours of the day the schedule runs. Leave empty for all.
minutes
array[integer]
The minutes the schedule runs. Required on POST for a cron schedule.
months
array[integer]
The months of the year the schedule runs. Leave empty for all.
weekdays
array[integer]
The weekdays the schedule runs. Leave empty for all.
svm
name
string
The name of the SVM.
uuid
string
schedule
Complete schedule information
cluster
cluster
cron
cron
interval
string
name
string
scope
string
svm
svm
type
string
Schedule type
uuid
string
Job schedule UUID
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
