REST API reference
Load CIFS local users, groups and group membership files from a URL
Loads CIFS local users, groups, and group memberships from a specified URL, replacing the current configurations with the new file contents. Use this when you need to update or refresh CIFS user and group data on your system.
HTTP method and endpoint
POST /protocols/cifs/users-and-groups/bulk-import/{svm.uuid}
Introduced in
ONTAP 9.11
Usage notes
Loads CIFS local users,groups and group memberships file from the specified URL.
Important notes
Existing CIFS local users, groups, and group memberships will be replaced with the contents of the file.
Required properties
  • import_uri.path
  • decryption_password
Optional properties
  • import_uri.username
  • import_uri.password
  • vserver cifs users-and-groups import load-from-uri
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
svm.uuid
string
path
True
Request Body
Name Type Description
decryption_password
string
Password to decrypt the compressed file.
import_uri
import_uri
status_uri
status_uri
svm
svm
Example request
  "decryption_password": "string",
  "import_uri": {
    "password": "string",
    "path": "http://web.sample.com/web1/file1.7z",
    "username": "user1"
  "status_uri": {
    "username": "user1"
  "svm": {
    "name": "svm1",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
655688
Invalid file decryption password. Valid password characters are: a-z, A-Z, and 0-9.
655661
URI username, URI password and the file decryption password cannot exceed 128 characters.
655689
File decryption password cannot be empty.
655399
CIFS server does not exist.
655683
Domain Security Identifier is already present in Active Directory.
655685
Cluster is busy processing a local users and groups transition task.
655687
Unknown file schema version.
655690
Processing the import file failed. Check the file decryption password, compression format and content.
655691
Error occured before processing the file. Verify the input parameters.
655692
Domain name that qualifies the local users and groups must match the CIFS server name.
655693
All local users and local groups must be prefixed with the NetBIOS domain name.
655693
Well-known user of group will not be present in this SVM.
655695
Group membership of the specified user will not be created.
655697
Failed processing a line of the bulk import file.
655698
Failed to parse a line of the bulk import file. Check the syntax and contents.
655699
Invalid number of elements in a line of the bulk import file.
655700
Failed processing a field index of a line in the input bulk import file.
655701
Unknown element type.
655702
Invalid URI.
655703
Failed to download the import file. Network error occured.
string
detailed_status
code
string
Code corresponding to the import status failure.
message
string
Detailed description of the import status.
import_uri
password
string
Password of the specified URI.
path
string
URI from which to load the input file containing the CIFS local users and groups. The file must be encrypted using the 7zip utility. URI can be FTP or HTTP.
username
string
Username of the specified URI.
status_uri
password
string
path
string
username
string
svm
name
string
The name of the SVM.
uuid
string
local_cifs_users_and_groups_import
decryption_password
string
import_uri
import_uri
status_uri
status_uri
svm
svm
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
