Load CIFS local users, groups and group membership files from a URL
POST /protocols/cifs/users-and-groups/bulk-import/{svm.uuid}
Introduced In: 9.11
Loads CIFS local users,groups and group memberships file from the specified URL.
Important notes
Existing CIFS local users, groups, and group memberships will be replaced with the contents of the file.
Required properties
import_uri.path
decryption_password
Optional properties
import_uri.username
import_uri.password
Related ONTAP commands
vserver cifs users-and-groups import load-from-uri
return_timeout  |
integer  |
query  |
False  |
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
Request Body
| Name | Type | Description |
decryption_password  |
string  |
Password to decrypt the compressed file.  |
elements_ignored  |
integer  |
Number of elements ignored.  |
elements_imported  |
integer  |
Number of elements successfully imported.  |
import_uri  |
state  |
string  |
Operation status.  |
status_uri  |
svm  |
SVM, applies only to SVM-scoped objects.  |
Example request
  "decryption_password": "string",
  "elements_ignored": 0,
  "elements_imported": 0,
  "import_uri": {
    "password": "string",
    "path": "http://web.sample.com/web1/file1.7z",
    "username": "user1"
  "state": "string",
  "status_uri": {
    "username": "user1"
  "svm": {
    "name": "svm1",
Status: 202, Accepted
job  |
  "job": {
    "uuid": "string"
Headers
| Name | Description | Type |
Location  |
Useful for tracking the resource location  |
string  |
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
655688  |
Invalid file decryption password. Valid password characters are: a-z, A-Z, and 0-9.  |
655660  |
This operation is only permitted on data SVMs.  |
655661  |
URI username, URI password and the file decryption password cannot exceed 128 characters.  |
655689  |
File decryption password cannot be empty.  |
655399  |
CIFS server does not exist.  |
655683  |
Domain Security Identifier is already present in Active Directory.  |
655685  |
Cluster is busy processing a local users and groups transition task.  |
655687  |
Unknown file schema version.  |
655690  |
Processing the import file failed. Check the file decryption password, compression format and content.  |
655691  |
Error occurred before processing the file. Verify the input parameters.  |
655692  |
Domain name that qualifies the local users and groups must match the CIFS server name.  |
655693  |
All local users and local groups must be prefixed with the NetBIOS domain name.  |
655693  |
Well-known user of group will not be present in this SVM.  |
655695  |
Group membership of the specified user will not be created.  |
655697  |
Failed processing a line of the bulk import file.  |
655698  |
Failed to parse a line of the bulk import file. Check the syntax and contents.  |
655699  |
Invalid number of elements in a line of the bulk import file.  |
655700  |
Failed processing a field index of a line in the input bulk import file.  |
655701  |
Unknown element type.  |
655702  |
Invalid URI.  |
655703  |
Failed to download the import file. Network error occurred.  |
href  |
string  |
_links
detailed_status
code  |
string  |
Code corresponding to the import status failure.  |
message  |
string  |
Detailed description of the import status.  |
import_uri
password  |
string  |
Password of the specified URI.  |
path  |
string  |
URI from which to load the input file containing the CIFS local users and groups. The file must be encrypted using the 7zip utility. URI can be FTP or HTTP.  |
username  |
string  |
Username of the specified URI.  |
status_uri
password  |
string  |
path  |
string  |
username  |
string  |
svm
name  |
string  |
The name of the SVM. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
local_cifs_users_and_groups_import
string  |
elements_ignored  |
integer  |
elements_imported  |
integer  |
import_uri  |
state  |
string  |
Operation status.  |
status_uri  |
svm  |
job_link
uuid  |
string  |
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
