REST API reference
Create an export policy rule
Creates an export policy rule to define access permissions for specific clients on volumes. This allows you to tailor security settings based on the needs of different client groups.
HTTP method and endpoint
POST /protocols/nfs/export-policies/{policy.id}/rules
Introduced in
ONTAP 9.6
Required properties
  • policy.id - Existing export policy for which to create an export rule.
  • clients.match - List of clients (hostnames, ipaddresses, netgroups, domains) to which the export rule applies.
  • ro_rule - Used to specify the security type for read-only access to volumes that use the export rule.
  • rw_rule - Used to specify the security type for read-write access to volumes that use the export rule.
Optional property
  • index - Used to specify the index number of the export rule that you want to create. If you specify an index number that already matches a rule, the index number of the existing rule is incremented, as are the index numbers of all subsequent rules, either to the end of the list or to an open space in the list. If you do not specify an index number, the new rule is placed at the end of the policy's list.
Default property values
If not specified in POST, the following default property values are assigned:
  • protocols - any
  • anonymous_user - none
  • superuser - any
  • allow_device_creation - true
  • ntfs_unix_security - fail
  • chown_mode - restricted
  • allow_suid - true
  • vserver export-policy rule create
policy.id
integer
path
True
Export Policy ID
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
boolean
Specifies whether or not device creation is allowed.
allow_suid
boolean
Specifies whether or not SetUID bits in SETATTR Op is to be honored.
anonymous_user
string
User ID To Which Anonymous Users Are Mapped.
chown_mode
string
Specifies who is authorized to change the ownership mode of a file.
clients
array[export_clients]
Array of client matches
index
integer
Index of the rule within the export policy.
ntfs_unix_security
string
NTFS export UNIX security options.
policy
policy
protocols
array[string]
ro_rule
array[string]
Authentication flavors that the read-only access rule governs
rw_rule
array[string]
Authentication flavors that the read/write access rule governs
superuser
array[string]
Authentication flavors that the superuser security type governs
svm
svm
Example request
  "anonymous_user": "string",
  "chown_mode": "string",
  "clients": [
      "match": "0.0.0.0/0"
  "ntfs_unix_security": "string",
  "policy": {
    "name": "string"
  "protocols": [
    "string"
  "ro_rule": [
    "string"
  "rw_rule": [
    "string"
  "superuser": [
    "string"
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records
integer
Number of Export Rule records
records
array[export_rule]
  "num_records": 1,
  "records": [
      "clients": [
      "policy": {
        "name": "string"
      "protocols": [
        "string"
      "ro_rule": [
        "string"
      "rw_rule": [
        "string"
      "superuser": [
        "string"
      "svm": {
        "name": "svm1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
1703954
Export policy does not exist
1704036
Invalid clientmatch: missing domain name
1704037
Invalid clientmatch: missing network name
1704038
Invalid clientmatch: missing netgroup name
1704039
Invalid clientmatch
1704040
Invalid clientmatch: address bytes masked out by netmask are non-zero
1704041
Invalid clientmatch: address bytes masked to zero by netmask
1704042
Invalid clientmatch: too many bits in netmask
1704043
Invalid clientmatch: invalid netmask
1704044
Invalid clientmatch: invalid characters in host name
1704045
Invalid clientmatch: invalid characters in domain name
1704050
Invalid clientmatch: clientmatch list contains a duplicate string. Duplicate strings in a clientmatch list are not supported
1704051
Warning: Not adding any new strings to the clientmatch field for ruleindex. All of the match strings are already in the clientmatch list
1704064
Clientmatch host name too long
1704065
Clientmatch domain name too long
3277000
Upgrade all nodes to Data ONTAP 9.0.0 or above to use krb5p as a security flavor in export-policy rules
3277083
User ID is not valid. Enter a value for User ID from 0 to 4294967295
string
export_clients
match
string
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
  • As a hostname; for instance, host1
  • As an IPv4 address; for instance, 10.1.12.24
  • As an IPv6 address; for instance, fd20:8b1e:b255:4071::100:1
  • As an IPv4 address with a subnet mask expressed as a number of bits; for instance, 10.1.12.0/24
  • As an IPv6 address with a subnet mask expressed as a number of bits; for instance, fd20:8b1e:b255:4071::/64
  • As an IPv4 address with a network mask; for instance, 10.1.16.0/255.255.255.0
  • As a netgroup, with the netgroup name preceded by the @ character; for instance, @eng
  • As a domain name preceded by the . character; for instance, .example.com
policy
id
integer
Export policy ID
name
string
Export policy name
svm
name
string
The name of the SVM.
uuid
string
export_rule
boolean
allow_suid
boolean
anonymous_user
string
chown_mode
string
clients
index
integer
ntfs_unix_security
string
policy
policy
protocols
array[string]
ro_rule
array[string]
rw_rule
array[string]
superuser
array[string]
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
