Create an export policy rule
Creates an export policy rule to define access permissions for clients interacting with your storage resources. This operation is useful for specifying security types for read-only and read-write access to volumes.
HTTP method and endpoint
POST /protocols/nfs/export-policies/{policy.id}/rules
Introduced in
ONTAP 9.6
Required properties
policy.id- Existing export policy for which to create an export rule. -
clients.match- List of clients (hostnames, ipaddresses, netgroups, domains) to which the export rule applies. -
ro_rule- Used to specify the security type for read-only access to volumes that use the export rule. -
rw_rule- Used to specify the security type for read-write access to volumes that use the export rule.
Optional property
index- Used to specify the index number of the export rule that you want to create. If you specify an index number that already matches a rule, the index number of the existing rule is incremented, as are the index numbers of all subsequent rules, either to the end of the list or to an open space in the list. If you do not specify an index number, the new rule is placed at the end of the policy's list.
Default property values
If not specified in POST, the following default property values are assigned:
protocols- any -
anonymous_user- none -
superuser- any -
allow_device_creation- true -
ntfs_unix_security- fail -
chown_mode- restricted -
allow_suid- true -
allow_nfs_tls_only- false
Related ONTAP commands
vserver export-policy rule create
Learn more
policy.id |
integer |
path |
True |
Export Policy ID |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
allow_device_creation |
boolean |
Specifies whether or not device creation is allowed. |
allow_nfs_tls_only |
boolean |
Specifies whether to allow NFS access only over TLS connections. |
allow_suid |
boolean |
Specifies whether or not SetUID bits in SETATTR Op is to be honored. |
anonymous_user |
string |
User ID To Which Anonymous Users Are Mapped. |
chown_mode |
string |
Specifies who is authorized to change the ownership mode of a file. |
clients |
array[export_clients] |
Array of client matches |
index |
integer |
Index of the rule within the export policy. |
ntfs_unix_security |
string |
NTFS export UNIX security options. |
policy |
protocols |
array[string] |
ro_rule |
array[string] |
Authentication flavors that the read-only access rule governs |
rw_rule |
array[string] |
Authentication flavors that the read/write access rule governs |
superuser |
array[string] |
Authentication flavors that the superuser security type governs |
svm |
Example request
"anonymous_user": "string",
"chown_mode": "string",
"clients": [
"match": "0.0.0.0/0"
"ntfs_unix_security": "string",
"policy": {
"name": "string"
"protocols": [
"string"
"ro_rule": [
"string"
"rw_rule": [
"string"
"superuser": [
"string"
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of Export Rule records |
records |
array[export_rule] |
"num_records": 1,
"records": [
"clients": [
"policy": {
"name": "string"
"protocols": [
"string"
"ro_rule": [
"string"
"rw_rule": [
"string"
"superuser": [
"string"
"svm": {
"name": "svm1",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1703954 |
Export policy does not exist |
1704036 |
Invalid clientmatch: missing domain name |
1704037 |
Invalid clientmatch: missing network name |
1704038 |
Invalid clientmatch: missing netgroup name |
1704039 |
Invalid clientmatch |
1704040 |
Invalid clientmatch: address bytes masked out by netmask are non-zero |
1704041 |
Invalid clientmatch: address bytes masked to zero by netmask |
1704042 |
Invalid clientmatch: too many bits in netmask |
1704043 |
Invalid clientmatch: invalid netmask |
1704044 |
Invalid clientmatch: invalid characters in host name |
1704045 |
Invalid clientmatch: invalid characters in domain name |
1704050 |
Invalid clientmatch: clientmatch list contains a duplicate string. Duplicate strings in a clientmatch list are not supported |
1704054 |
Invalid clientmatch: invalid characters in netgroup name. Valid characters for a netgroup name are 0-9, A-Z, a-z, ".", "_" and "-" |
1704064 |
Clientmatch host name too long |
1704065 |
Clientmatch domain name too long |
1704070 |
Export policy rule already exists. The export policy rule was not created because an export policy rule with the same values already exists. |
3277000 |
Upgrade all nodes to ONTAP 9.0.0 or above to use krb5p as a security flavor in export-policy rules |
3277083 |
User ID is not valid. Enter a value for User ID from 0 to 4294967295 |
3277162 |
The specified "index", 0, is invalid. Valid values are values from 1 to 4294967295 |
3277163 |
The system cannot automatically specify an "index" for this rule, because a rule with "index" 4294967295 exists. Either specify an unused "index", or update the existing rules so that "index" 4294967295 is not used. |
3277149 |
The "Anon" field cannot be an empty string |
3277249 |
Setting "allow-cache-async-writes" to "true" in export-policy rules requires an effective cluster version of 9.19.1 or later. |
href |
string |
_links
export_clients
match |
string |
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
policy
id |
integer |
Export policy ID |
name |
string |
Export policy name |
svm
name |
string |
uuid |
string |
export_rule
boolean |
boolean |
allow_suid |
boolean |
anonymous_user |
string |
chown_mode |
string |
clients |
index |
integer |
string |
policy |
protocols |
array[string] |
ro_rule |
array[string] |
rw_rule |
array[string] |
superuser |
array[string] |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
