REST API reference
Create a Vscan On-Demand policy
Creates a Vscan On-Demand policy on a data SVM, enabling targeted virus scanning according to specified paths and schedules. Use this endpoint to define scanning parameters such as file extensions and scheduling to enhance your data protection strategy.
HTTP method and endpoint
POST /protocols/vscan/{svm.uuid}/on-demand-policies
Introduced in
ONTAP 9.6
Usage notes
Created only on a data SVM.
Important notes:
  • Only one policy can be scheduled at a time on an SVM. Use schedule name or schedule uuid to schedule an On-Demand policy.
  • Scanning must be enabled on the SVM before the policy is scheduled to run.
  • The exclude_extensions setting overrides the include_extensions setting. Set scan_without_extension to true to scan files without extensions.
Required properties
  • svm.uuid - Existing SVM in which to create the Vscan On-Demand policy.
  • name - Name of the Vscan On-Demand policy. Maximum length is 256 characters.
  • log_path - Path from the Vserver root where the On-Demand policy report is created.
  • scan_paths - List of paths that need to be scanned.
  • schedule - Scan schedule. It is recommended to set the schedule property, as it dictates when to scan for viruses.
Default property values
If not specified in POST, the following default property values are assigned:
  • include_extensions - *
  • max_file_size - 10737418240
  • scan_without_extension - true
  • vserver vscan on-demand-task create
  • vserver vscan on-demand-task schedule
return_records
boolean
query
False
  • Default value:
svm.uuid
string
path
True
Request Body
Name Type Description
log_path
string
The path from the Vserver root where the task report is created.
name
string
On-Demand task name
scan_paths
array[string]
schedule
schedule
Schedule of the task.
scope
scope
svm
svm
Example request
  "log_path": "/vol0/report_dir",
  "name": "task-1",
  "scan_paths": [
    "/vol1/",
    "/vol2/cifs/"
  "schedule": {
    "name": "weekly",
  "scope": {
    "exclude_extensions": [
      "mp3",
      "mp4"
    "exclude_paths": [
      "/vol1/cold-files/",
      "/vol1/cifs/names"
    "include_extensions": [
      "vmdk",
      "mp*"
    "max_file_size": 10737418240
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records
integer
Number of records
records
array[vscan_on_demand]
  "num_records": 1,
  "records": [
      "name": "task-1",
      "scan_paths": [
        "/vol1/",
        "/vol2/cifs/"
      "schedule": {
        "name": "weekly",
      "scope": {
          "mp3",
          "mp4"
        "exclude_paths": [
          "/vol1/cifs/names"
          "vmdk",
          "mp*"
      "svm": {
        "name": "svm1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
10027101
The file size must be in the range 1KB to 1TB
10027107
The include extensions list cannot be empty. Specify at least one extension for inclusion.
10027164
An On-Demand policy cannot be scheduled, as the Vscan is disabled. Enable the Vscan and retry the operation.
10027167
The specified schedule does not exist. Create the schedule or create a policy without specifying the schedule.
10027168
The specified scan path does not exist. The scan path must be specified from the root of the SVM, and must begin with UNIX path delimiters (use “/” not “\”)
10027169
The specified scan path is not supported for scanning.
10027173
The new On-Demand policy cannot be created as the SVM has reached the maximum number of On-Demand policies allowed. Delete an existing policy in order to create a new policy.
10027174
The specified exclude path is invalid. The path must be specified from the root of the SVM, and must begin with UNIX path delimiters (use "/" not "\")
10027175
An On-Demand policy cannot be scheduled as the Vserver is not in an operational state.
10027176
The log-path specified does not exist. The log path must be specified from the root of the SVM, and must begin with UNIX path delimiters (use “/” not “\”).
10027177
The log path specified is not supported.
10027253
The number of paths specified exceeds the configured maximum number of paths. You cannot specify more than the maximum number of configured paths.
10027254
The number of extensions specified exceeds the configured maximum number of extensions. You cannot specify more than the maximum number of configured extensions.
10027255
Another policy is already scheduled. Only one policy per SVM is allowed to be scheduled at any one time. Create a policy without specifying a schedule.
string
schedule
name
string
Job schedule name
uuid
string
Job schedule UUID
scope
exclude_extensions
array[string]
List of file extensions for which scanning is not performed.
exclude_paths
array[string]
List of file paths for which scanning must not be performed.
include_extensions
array[string]
List of file extensions to be scanned.
max_file_size
integer
Maximum file size, in bytes, allowed for scanning.
boolean
Specifies whether or not files without any extension can be scanned.
svm
name
string
The name of the SVM.
uuid
string
vscan_on_demand
Use On-Demand scanning to check files for viruses on a schedule. An On-Demand policy defines the scope of an On-Demand scan.
log_path
string
name
string
On-Demand task name
scan_paths
array[string]
schedule
schedule
scope
scope
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
